I have a complete dealer installed A/C system that was in my '72 240z. The former owner included a new/unused condensor, new compressor, and new dryers along with the foot-well box coil, switch, etc. Is there any market for this antiquated system or should I talk to the local scrappers to see what they'd give me for the metal? I figure if I ever want A/C in the Z I would buy a newer version from VintageAir or somewhere similar. Any thoughts?
https://www.classiczcars.com/forums/topic/43797-dealer-installed-ac/
I'm interested if the price is reasonable.
Send me a PM if you care to discuss it.
Thanks!
Jim D.
"Zup"
Owners interested in adding "period correct" AC may be interested in your system. As you noted, a newer system with a rotary compressor is now the way to go, unless it's important to keep the Z as it would have been in '72. I still have the unit from my '71 in a box in the garage after modernizing.
Dennis
Here's a picture of what I have:
- Condensor (new, unused with plastic plugs still in the ends
- Airbox coil (used, all of the 'guts' are still inside)
- Compressor (net, unused in original box, appears to have been ordered by the previous owner to replace the original)
- 2 Dryers (both look new, but hard to tell)
- A/C Switch with temperature sensor (used)
- Pulley with electromagnetic clutch & belt (appears to be used)
- Box of miscellaneous fittings, hoses, connectors, etc.
I should be able to pull the mounting bracket off of my engine block as well (not pictured) if anyone is seriously interested in this kit.
