Email logins are now active ×
rocker arms fell off
silvey19k
The gouge on your cam looks like it's on the base circle so it won't have any pressure on it, and most likely won't cause further damage.
Although, in your pictures it looks like the lash might have been tight on a few lobes. The base circles are shiny like they've had the rocker arms riding tight on them.
Just a couple more observations.
On second thought, where's there's a dent, there will be displaced, raised, metal.
Make sure that the area around the dent doesn't have a raised edge that would wear the rocker arm and screw up your lash measurements. You're in uncharted territory. Some very careful work with a whetstone might do the trick.
  • Who's Online   1 Member, 0 Anonymous, 505 Guests (See full list)
