Posted July 15, 201212 yr comment_395839 enigne is running a bit rough and im thinking its the timing. I've read the pulley notch is supposed to be pointed at the 10° mark for a 1977 Z. is this the same for the 78?thanks guys,sam Link to comment https://www.classiczcars.com/forums/topic/43819-timing-for-1978-280z/ Share on other sites More sharing options...
July 15, 201212 yr comment_395841 There should be a sticker on the bottom side of the hood with the timing spec. Link to comment https://www.classiczcars.com/forums/topic/43819-timing-for-1978-280z/#findComment-395841 Share on other sites More sharing options...
July 15, 201212 yr Author comment_395843 indeed there is, thanks a lot, man. Link to comment https://www.classiczcars.com/forums/topic/43819-timing-for-1978-280z/#findComment-395843 Share on other sites More sharing options...
