I always use the Permatex aviation gasket sealer (aka molasses) to be safe for most oil and water gaskets.
Funny you say that. Befor posting this thread I purchased a little can type 3 aviation gasket sealer. the brown stuff with the brush. should it not be used on the front cover gaskets?
The FSM says to aplly sealer to the front cover and four corners.
I use the Permatex High Tack spray-on sealer. It's not as messy as the brown stuff and comes off without too much work the next time you have the cover off. I tend to have my race motor apart fairly often, so I don't want to spend a lot of time cleaning the surfaces. The red spray stuff comes clean with a razor blade and scotch brite. I've been using it on front covers for 25 years and have never had a leak. I think the can I use has lasted about 10 years and has done 10+ Z motors.
Simply lay the gaskets on cardboard and spray them with a light coating of the sticky red sealant. After a few minutes, turn them over and repeat. Give them another few minutes to dry a bit and install.
http://www.permatex.com/products/Automotive/automotive_gasketing/gasket_sealants/auto_Permatex_High_Tack_Spray-A-Gasket_Sealant.htm
