well today i was putting my z back together. to go to the shop and when i first got into it the chain was tight and now there is some slack on the drivers side of the chain i moved the cam to install the rockers i lost and i was going to ajust the rockers when i noticed that there was some slack now in the chain. what could cause this?
Another thought - the cam tensioner is driven by oil pressure. If the engine wasn't running... the tensioner can get pushed back a bit.
When you get everything back together - start the engine and get some oil pressure - the chain should be tight.
FWIW,
Carl B.
Ok cool i've worked on Honda engines and Chevy this motor is still a puzzle I feel I can work on this one there won't be one I can't do just now I'm short on time so it has to go to a shop
