Just went to change my oil and found the filter canister somewhat dented in at the outboard edges. This was a WIX filter that the shop I had work on my carbs put on because it was dumping fuel into the crankcase. It is smaller than the factory filter but I am not sure that would cause it to collapse!
Any ideas? I am putting a factory filter on with the oil change...
We figured it out... The shop is owned by a friend and he thinks one of his guys got over-zealous with the filter wrench when he put it on. I thought it might have collapsed but that isn't likely...
