HAHAHA you are right. I'm in pretty deep. Willwoods are on the list. Just don't know if I can swallow the 200 extra for red. Come on really? $200 extra. Thats just not right. The springs are just the eibach kit. They say they don't lower the height on the 240 but it does sit lower in the front now. I havn't started with the rear yet. I'm installing an R200 so i'll do it while i'm changing the rear diff. Here is what I was entertaining myself with today. Looks pretty good. I'm in the midst of re doing some wiring with shielded so wiring is a mess. This car will be pretty nice when its done. I don't know how the T5 will feel but shifting it just out of the car it feels amazing. I can't wait to see. Thats a really nice Z madkaw. I noticed you say you are running the subi LSD. What axles and companion flanges did you use?
Edited by MotoManMike
LOL. The real work hasn't started yet. I'm not looking forward to changing this rear end and suspension. 40 year old bolts never play nice. I've got to come pay you a visit. I need to get that rear end, unless you can pick it up for me. I need to find a turbo manual pinion flange for an R200. Thats the only unicorn at the moment. If you see a listing for one let me know. I know you look around quite a bit on the net at parts and cars.
200.00 $ for red paint? If you are saying that it's all bling, I will strongly disagree. But I can understand money!!
As far as the subi rear, the adapters are the expensive units. John Coffey sells them over at hybridz for about 500$. Very nice pieces and John does good business. The good part is that Subi-LSD units are avialable and at a reasonable price. Weigh it against a 35 year old r200 that sell for 750.00$ and it sounds much better.
yeah, same brakes, $200 more for red paint. Its a joke. They brake just the same being black so its an obvious choice for me. I want that set up because other upgrades i've seen might have fitment issues due to my wheel size. I don't want to have to go to a 16 or 17 inch wheel. I'm way off on that project though. I put new stock calipers on it and the rear drums do work so it brakes pretty well for what it is. I just noticed as soon as I got it running halfway right, once it got into boost the speeds went up pretty quickly and the stock brake set up isn't up to snuff with the power. So it will be upgraded at some point in the future. My main goals are to get this rear end set up so I can put in this T-5 and finish the rear suspension. The T-5 all came from an S30 so the drive shaft was already shortened and the hanger adjusted. I've got the rear sway bar set up with brackets and all but i want to see how it handles first after the suspension is fresh. I've read alot on the topic of rear sways on the 240 and many don't like them installed. Some do. I won't know until I see for myself I guess. I'll keep posting as it goes on. Thanks for looking guys.
I'll check out the rear set up they sell. I've sourced most of the parts I need for under $500 to do a rear R200 so I'm going to try it for awhile. It can't be any worse than what it is. This thing sounds terrible. Whines at speed and has some play.
  • 2 months later...
I've got my R200 up. New diff front mount. New rear T3 rear arms. Eibachs and kyb's. I have to relocate the fuel pump because the R200 mustache bar sits further back than the R180 hanger. Coming along. Transmission and clutch will be next.
  • 1 year later...
I never kept up on this thread however an update. This car is still running great. MS is sorted and the car is a blast to drive. It ran a 13.90 the first pass at the drag strip and handles great on the street. Fun fun fun. I'm working on number 2 now. She's a rusty one....
Guest
Reply to this topic...
