Series 1 240z with Toyota pickup calipers?
Currently the stock refreshed master vac and new master cylinder don't cut it.... not enough power assist and too much excursion.
I am thinking an 83 280zx master with larger master vac that can fit w/o drilling firewall... but which one?
I've been very happy with the Wilwood 1" master on a stock booster with Wilwood brakes.
http://www.wilwood.com/MasterCylinders/MasterCylinderProd.aspx?itemno=260-8794
I was running the 15/16" until it failed. I couldn't find a rebuild kit for it so I switched to the Wilwood master. It requires a small amount of filing on the base of the master to get it to fit but once installed you can't see the modification and it looks very close to stock.
Here is a thread on hybrid Z about it...
http://forums.hybridz.org/index.php/topic/102754-a-one-inch-diameter-brake-master-cylinder-for-the-s30-z-cars/
I'm running the stock Nissan/Datsun 7/8 inch M/C with front and rear Willwood brakes.......works beautiful!
Edited by Diseazd
The stock booster is working great for me. Rock auto seems to still sell them.
Is this your 71 or 73? I read that 73 booster is bigger?
On mine with 13'' rotors at all corners,two pistons PBR's at the front and one piston PBR's on the rear, has a Cardone rebuilt booster for an early Z and she stops on a dime ;)
Do you know if the 73 will bolt in Series 1 or does it need the 4 holes wider?
If I have to drill I'll try to find the biggest that will fit.
Reference
From Rock Auto
70,71: 535245 (?")
72,73: 535246 (7")
73: 535246 and 535104 (7" and 8.5")
75,76,77,78: 535104 and 535065 (8.5" and 10")
[TABLE=class: main, width: 955]
<tbody>[TR]
[TH=align: center]1970 NISSAN 240Z 2.4L L6 : Brake/Wheel Hub : Power Brake Booster Wiki[/TH]
[TH=align: center]Price[/TH]
[TH=align: center]Core[/TH]
[TH=align: center]Total[/TH]
[/TR]
[TR=class: part0, bgcolor: #F0F0F0]
[TD=class: alternate0][TABLE=class: parts, width: 728]
<tbody>[TR]
[TD=class: left, align: left][TABLE=class: layout, width: 676]
<tbody>[TR]
[TD=class: partlayout]A-1 CARDONE Part # 535245 MoreInfo2.png Reman. A-1 CARDONE Vacuum Booster
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[TD=class: right, align: right][/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[TD=class: center leftrightborder pricebreakdown alternate0, align: center]CAD$77.10[/TD]
[TD=class: center leftrightborder middleborder pricebreakdown alternate0, align: center]CAD$29.73[/TD]
[TD=class: center boldfont leftrightborder pricebreakdown alternate0, align: center]CAD$106.83[/TD]
[/TR]
[TD=class: alternate0 right, colspan: 3, align: right]Add Part [/TD]
[/TR]
</tbody>[/TABLE]
<tbody>[TR]
[TH=align: center]1971 NISSAN 240Z 2.4L L6 : Brake/Wheel Hub : Power Brake Booster Wiki[/TH]
[/TR]
<tbody>[TR]
<tbody>[TR]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
[/TD]
[/TR]
</tbody>[/TABLE]
<tbody>[TR]
[TH=align: center]1972 NISSAN 240Z 2.4L L6 : Brake/Wheel Hub : Power Brake Booster Wiki[/TH]
[/TR]
<tbody>[TR]
<tbody>[TR]
[TD=class: partlayout]A-1 CARDONE Part # 535246 MoreInfo2.png Reman. A-1 CARDONE Vacuum Booster
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[TD=class: center leftrightborder pricebreakdown alternate0, align: center]CAD$89.09[/TD]
[TD=class: center leftrightborder middleborder pricebreakdown alternate0, align: center]CAD$31.22[/TD]
[TD=class: center boldfont leftrightborder pricebreakdown alternate0, align: center]CAD$120.31[/TD]
[/TR]
[/TR]
</tbody>[/TABLE]
<tbody>[TR]
[TH=align: center]
1973 NISSAN 240Z 2.4L L6 : Brake/Wheel Hub : Power Brake Booster Wiki[/TH]
[TH=align: center]
Core[/TH]
[/TR]
<tbody>[TR]
[TD=class: left, align: left][TABLE=class: layout, width: 675]
<tbody>[TR]
[TD=class: partlayout]A-1 CARDONE Part # 535104 MoreInfo2.png Reman. A-1 CARDONE Vacuum Booster
with 8-1/2" Diameter Booster; w/o Master Cylinder[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[TD=class: center leftrightborder pricebreakdown alternate0, align: center]CAD$90.97[/TD]
[TD=class: center leftrightborder middleborder pricebreakdown alternate0, align: center]CAD$24.78[/TD]
[TD=class: center boldfont leftrightborder pricebreakdown alternate0, align: center]CAD$115.75[/TD]
[/TR]
[/TR]
[TR=class: part1, bgcolor: #E0E0E0]
[TD=class: alternate1][TABLE=class: parts, width: 728]
<tbody>[TR]
<tbody>[TR]
with 7" Diameter Booster; w/o Master Cylinder[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[TD=class: center leftrightborder pricebreakdown alternate1, align: center]CAD$89.09[/TD]
[TD=class: center leftrightborder middleborder pricebreakdown alternate1, align: center]CAD$31.22[/TD]
[TD=class: center boldfont leftrightborder pricebreakdown alternate1, align: center]CAD$120.31[/TD]
[/TR]
[TD=class: alternate1 right, colspan: 3, align: right]Add Part [/TD]
[/TR]
</tbody>[/TABLE]
<tbody>[TR]
[TH=align: center]1975 NISSAN 280Z 2.8L L6 : Brake/Wheel Hub : Power Brake Booster Wiki[/TH]
[/TR]
[TD=class: alternate0][TABLE=class: parts, width: 721]
<tbody>[TR]
[TD=class: left, align: left][TABLE=class: layout, width: 668]
<tbody>[TR]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
[/TR]
[TD=class: alternate1][TABLE=class: parts, width: 721]
<tbody>[TR]
<tbody>[TR]
[TD=class: partlayout]A-1 CARDONE Part # 535065 MoreInfo2.png Reman. A-1 CARDONE Vacuum Booster
with 10" Diameter Booster; w/o Master Cylinder[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[TD=class: center leftrightborder pricebreakdown alternate1, align: center]CAD$107.03[/TD]
[TD=class: center boldfont leftrightborder pricebreakdown alternate1, align: center]CAD$138.25[/TD]
[/TR]
[/TR]
</tbody>[/TABLE]
<tbody>[TR]
[TH=align: center]1978 NISSAN 280Z 2.8L L6 : Brake/Wheel Hub : Power Brake Booster Wiki[/TH]
[/TR]
<tbody>[TR]
<tbody>[TR]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
[/TR]
<tbody>[TR]
<tbody>[TR]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
</tbody>[/TABLE]
[/TD]
[/TR]
[/TR]
</tbody>[/TABLE]
