Posted August 16, 201212 yr comment_398789 i have a 73 260z with a 280z 5spd manual and stock 260 cluster.i idle at 660 according to timing gun.tach reads 2k at idle and 5500rpm on freeway(timing light reads 26xxrpm).do i need the speedo cable gear from the 280?any other thoughts help.thanks in advance.cheers-wombat Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/ Share on other sites More sharing options...
August 16, 201212 yr comment_398792 We already have a boobs thread on this site. And now you want to add trannys??? Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/#findComment-398792 Share on other sites More sharing options...
August 16, 201212 yr Author comment_398793 thanks... Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/#findComment-398793 Share on other sites More sharing options...
August 16, 201212 yr comment_398794 A different speedo gear is going to make no difference to what the tach reads at idle.You should only need a different speedo cable gear if you have changed diff ratios or radically changed tyre size, Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/#findComment-398794 Share on other sites More sharing options...
August 16, 201212 yr comment_398796 What Olzed is saying is that the tack is controlled electronically basically off the distributor. Tachs are notorious for going bad over the course of 40 years. It is possible to have them rebuilt, where they replace the guts. By the way, I remember the old days, when "blowing a tranny" just meant car trouble. Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/#findComment-398796 Share on other sites More sharing options...
August 19, 201212 yr Author comment_399193 Ok thanks. Just figured I'd ask before shelling out for gauges. My dash looks like the grand canyon anyway. The last owner took the liberty of filling the dash crack with white bathroom caulk and makes me want to throw up a little every time I see it. I feel the next project coming... Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/#findComment-399193 Share on other sites More sharing options...
August 20, 201212 yr comment_399232 The tachometer has a calibration trimmer. It is accessible through a small hole in the rear housing of the tach. Try adjusting it to match your timing gun. Link to comment https://www.classiczcars.com/forums/topic/44117-trannyspeedo-question/#findComment-399232 Share on other sites More sharing options...
