Posted January 24, 200322 yr comment_24396 hi, im thinking about installing a 77 280z fuel injected motor into a 73 240z. i have both cars complete, all wiring injectors ect..im wondering what all i need to do, i have the precessor and wiring from the 77 280z, but not sure what i need to do about the fuel lines, tanks, fuel pump, and ignition. will they interchange? if you know of a site or have done this swap id love to hear from you. thanks for any info. ronpotts@650dialup.com Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/ Share on other sites More sharing options...
April 14, 200322 yr comment_33930 Hi,I was considering this myself and did some research. The harness for the fuel injection will work, as long as you use all of the relays, etc. You need to open the requisite hole in the firewall to bring the ECU into the passenger compartment and install the Fuel Injection/pump relay under the drivers side dash area. The pump bracket will fit. I know you need the 280Z tank for the fittings. Breather line, pump supply line and line from pump to injectors and need a second fuel line for the return to the tank.I liked the idea because you get the light body with the smooth fuel injected engine.Didn't procced because ther was too much rust in the early 260 I was going to use.Hope this helps a little.Ed Palmer Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-33930 Share on other sites More sharing options...
August 31, 200321 yr comment_48212 I am planning on doing this swap also. I have a 76 L28 in a rusted up body, and a 240 with a good body. The 240 has a good engine in it, but I thought that the L28 would be a neat swap. Has anyone actually done this swap? If so I would sure appreciate any insight into the problems that I might run into.Is the result worth the work? I would imagine that the L28 would make the 240 move, but if anyone who has a 240 with the L28 would jump in and let me know if its worth the work I would sure appreciate it.Thanks-frozen Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-48212 Share on other sites More sharing options...
September 1, 200321 yr comment_48218 homemade stand alone fuel injection computer I know two people that are useing this. They bolth bought it and had a computer guy put it togather for them. They say its easy and never fails. Plus you get to say you have a fuel managment system you can program with your computer. Also did it yourself for under $200. :cheeky: Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-48218 Share on other sites More sharing options...
September 1, 200321 yr comment_48285 Carguy,Thanks for the link. That sure looks like it would be a pretty cool winter project. I have never liked the idea of not really understanding what was controlling my fuel system. I really think that being able to know exactly what was telling my fuel system what to do would be great and being able to modify it would be even better.I think I have a pretty good handle on what is going to required for the L28 into the 240 on the fuel side. What is going to have to be swapped on the ignition side?My thoughts are1. the dizzy will have to come over with the L282. the alternator will come over too (don't know if its reqd, but its new)3. the coil should come over (I think)I think that should be it. From what I understand the crank pickup is located in the dizzy, the fuel system needs to tie into the coil, and I should be taken care of.Can anyone think of what else is going to be req'd to swap over?thanks -frozen Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-48285 Share on other sites More sharing options...
September 2, 200321 yr comment_48331 this is all good info ! I'm looking at putting the injection system from a 280Z into ... a 280Z! its a radical concept, but I think it could work!(actually a retro-conversion from carbs - I'm a bit luckier than the others, the fuel return lines, etc, are all there) Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-48331 Share on other sites More sharing options...
September 3, 200321 yr comment_48449 The MegaSquirt FI system is going to be my next winter project.I'm thinking that it would work well on a twin throttle body injection setup off the standard inlet manifold. This would actually convince me to get rid of my flat tops. Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-48449 Share on other sites More sharing options...
September 5, 200321 yr comment_48615 Can anyone confirm that the only parts of the ignition system that needs to come over from the 280 to the 240 is the dizzy, coil, and alternator?Thanks-frozen Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-48615 Share on other sites More sharing options...
October 13, 200420 yr comment_98058 G'day all, I'm reviving this thread as last night I pulled the motor and box out of the 280zx to install into the 240.I want to gather info on what traps to look out for and ask a few Qu's. Once I've finished I'll post up the entire project.First thing I noticed is how much easier it is to move the 240 shell around the yard than the 280zx shell, which is motivating me even further as this 280zx really flys on the dirt.-Fuel linesI'll use the 280 elec fuel pump, but the return line on the 240 is smaller, can I use an adapter to connect it to the fi return rail? does size matter other wise will I have to change tanks too ( the 280zx tank will not fit)-Wire loomI disconnected the loom from the body and pulled it complete with the motor.When I took the loom harness off the ECU I had to disconnect a single spade connector and a three spade connector from the loom, should follow these under the dash and remove them? what do they control?thanks for any advise Steve Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-98058 Share on other sites More sharing options...
October 14, 200420 yr comment_98175 anyone?I'm going to fit up the motor and box this weekend but I don't know if you really need to change the small diameter return line? Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-98175 Share on other sites More sharing options...
October 21, 200420 yr comment_98830 I have put '78 head and F.I. on my L24 block -- All works well.I used the stock 240z fuel return line with out any trouble. The problem I have RIGHT NOW is that the hood will not closewith the stock 280z air cleaner mounted in the 280z factory position ( to high ).Any thoughts on what to do? I plan to try putting the mountingflange on the bottom of the radiator support instead of on top.- Jeff Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-98830 Share on other sites More sharing options...
January 29, 200520 yr comment_110624 anyone?I'm going to fit up the motor and box this weekend but I don't know if you really need to change the small diameter return line?Im guessing that you got it all sorted in the end?My intake and exhaust manifolds are going on tonight, and wiring will be happening next week. What this about a pump relay under the dash that someone mentioned?I might have to grab all the relays from a 280zx somewhere. Any other tricks other than the fuel lines/pump ? Link to comment https://www.classiczcars.com/forums/topic/4414-need-info-installing-fuel-inj-in-240z/#findComment-110624 Share on other sites More sharing options...
