Pulling engine and tranny for full rebuild
HermanM
As the title says, I'm going to be pulling my motor and tranny to do a complete rebuilt and transplant from a dead 260 to my running 260 in my home garage and I would love any help that anyone can give me, either advice/recommendations or even hands on if you're in the Sacrameto, Ca (916) area.
Please don't be shy on being blunt about your opinions bc this will be my first of atleast 3 engine rebuilds on the classic engines (I own 2 engines and am looking into picking up a 3rd)
Thanks for looking in
Suggestions:
Get an engine lift with tilter.
If it is a two ton lift, use the last 1/2 ton pin on the lift to maximize reach.
Remove the hood and radiator
Jack up the rear of the car at the differential to tilt it.
I'm picking up a host over the weekend but didn't think about a tilt or leveler bc the engine was just placed within the empty engine bay and not real attachments but maybe AN engine mount and not attached to the tranny. I assumed that since there was nothing in the way I should be able to pull it with no real issues as long as I have assistance pulling it
Yeah, they are seperate already. I was just going to jack up the body ant drop the tranny with the help of a car jack. Place the engine on a stand (it's been pre drained) and break down and rebuild. I've got close to $2k in parts on hold with just an idea and no knowledge if the engine state.
I know rebuilds are time and money. Those I have, advice and help is what I lack. My last rebuilt was a 92 dodge stealth twin turbo but I was able to put it at 450hp. I just need the right idea and I will make my Z fly
Take a bunch of pictures before you tear into it. Go to your local building supply and get some lacquer thinner and some small wire brushes, brass for the pistons, they're in the welding section and look like a toothbrush. You'll need a roll of painters tape and a Sharpie for labeling things as well as a box of zip-lock baggies for small parts. I left the bolts in the part and put a small wire on the backside to hold them in place or a paperclip. Put your stuff in boxes and write what's in the box on the boxes, you can keep them in the hatch. Clean and clean then clean some more, you'll be glad you did. Zedyones thread on his rebuild has the dimensions for a wooden crate you can build for your motors. I built one out of 2x6's but I think 1x6 would do and put wheels on the bottoms. I had never built one of these engines and Tom Monroe's "How to rebuild your L series" book from amazon.com was the best $20 I spent. Step by step instructions with lots of pictures.
That's been my whole idea so far. Restore my stock, matching numbers motor and tranny, with chrome and polished anything with steal braided lines. It may not be a show quality daily driver but it will sure look pretty haha.
