Posted August 27, 201212 yr comment_399893 Please advise me where to find rubber bushings and spindle pins for the rear of a 78/280z. I have read that poly bushings will cause a harsh ride and am wanting to go back original. Any advice is appreciated JB Link to comment https://www.classiczcars.com/forums/topic/44214-rear-suspension/ Share on other sites More sharing options...
August 27, 201212 yr comment_399895 Check out www.thezstore.com they have a lot of stock and performance parts for the Z &ZX models. www.blackdragonauto.com. has a wide range of stock and performance parts and you can order a hard copy catalogue online.See www.thezstore.com/page/TZS/CTGY/SSSC01C02 for stock mechanical rear suspension stuff. Edited August 27, 201212 yr by EuroDat Added link to stock mechanical the z store Link to comment https://www.classiczcars.com/forums/topic/44214-rear-suspension/#findComment-399895 Share on other sites More sharing options...
August 27, 201212 yr comment_399899 Don't overlook your local Nissan dealer. I am switching back to rubber bushings away from poly, I don't like the ride quality. Courtesy Nissan Parts website came up with all the bushings for the rear LCA's. The inner bushings are 55554-E4100 at $13.78 and 55555-E4100 at $11.49. Outer bushings are 55541-E4100 at $9.57. As MSA points out, they are all the same for 240-260-280Z's. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/44214-rear-suspension/#findComment-399899 Share on other sites More sharing options...
August 28, 201212 yr Author comment_399924 Thanks very much for the replies. I will check with the dealer for bushings ans spindle pins, Thanks again. JB Link to comment https://www.classiczcars.com/forums/topic/44214-rear-suspension/#findComment-399924 Share on other sites More sharing options...
August 29, 201212 yr comment_400074 Don't overlook your local Nissan dealer. I am switching back to rubber bushings away from poly, I don't like the ride quality. Courtesy Nissan Parts website came up with all the bushings for the rear LCA's. The inner bushings are 55554-E4100 at $13.78 and 55555-E4100 at $11.49. Outer bushings are 55541-E4100 at $9.57. As MSA points out, they are all the same for 240-260-280Z's. Hope this helps.I think the key is to leave at least one rubber interface in any of the four suspension points. That is, don't use 100% poly in your suspension. Link to comment https://www.classiczcars.com/forums/topic/44214-rear-suspension/#findComment-400074 Share on other sites More sharing options...
