December 12, 201212 yr comment_409065 Cygnus: What kind or brand paint did you used? Brushed or ? Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-409065 Share on other sites More sharing options...
December 12, 201212 yr comment_409078 Cygnus: What kind or brand paint did you used? Brushed or ? Silver brake caliper paint. Spray on. I think it was VHT brand. Edited December 12, 201212 yr by cygnusx1 Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-409078 Share on other sites More sharing options...
March 28, 201312 yr Author comment_418997 It's still too cold to try the lemon juice soup on the BBQ so I am trying another interesting carb degreaser: Pine-Sol. A Datsun 510 DAF-328 carb is now soaking in my basement. Have a look at this thread: The Pine Sol Degreaser Thread - ADVrider Edited March 28, 201312 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-418997 Share on other sites More sharing options...
March 28, 201312 yr comment_419011 I tried the lemon juice method a few months ago on a set of carbs. While it is a cheap alternative to cleaning them up, in the end I was not completely happy with the results. The process took me an afternoon to setup and do. The smell was pretty bad, and the carbs didn't come out as clean as I was hoping. There was still grease and a tarnished finish on them. If you're looking for an easy way to really clean your carbs, go down to the local car parts store and get a gallon of carb cleaner with the basket inside. I did that, and left the carb in it over night. The results were far better than lemon juice and there wasn't a mess to clean up. Chase Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419011 Share on other sites More sharing options...
March 28, 201312 yr comment_419015 I just sent my carbs to glass blasting, results were awesome (and cheapish) Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419015 Share on other sites More sharing options...
March 29, 201312 yr Author comment_419150 Well I am not impressed. I soaked for a few hours and it worked nicely at removing the crud and varnish. I let sit for another 24hrs and it removed a lot of cad/zinc plating and darkened the aluminum. I guess it is just an acid like any other. When I disassembled the carb it was messy and gooey in the internal passages and the brass jets and fittings darkened.It was ok after spraying with carb cleaner and oiling the iron base of the DAF328Bottom line: I feel dumb as the fools that post this BS on the net. It is amazing that many just soak in the Pine-Sol and don't even take the carbs apart afterwards.I do not recommend this. I have a Weber DGV that I will boil in soapy water and see what happens. Stay away from acids unless you plan to replate the cad/zinc!!!! Edited March 29, 201312 yr by Blue Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419150 Share on other sites More sharing options...
March 30, 201312 yr comment_419166 Thanks for trying this and taking one for the team Blue...I wish you luck in recovering from this Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419166 Share on other sites More sharing options...
March 30, 201312 yr comment_419171 Bummer. I don't know what the offending ingredient is, but in thier FAQ:Pine-Sol® Ingredients, How to Use Coupons & Other FAQ'sWhere should I NOT use Pine-Sol® Cleaners?We do not recommend using Pine-Sol® Original Pine® Multi-Surface Cleaner on aluminum, copper or marble surfaces. We also do not recommend using Pine-Sol® Cleaners on cars, on dishes, or as a pet shampoo. Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419171 Share on other sites More sharing options...
March 30, 201312 yr Author comment_419174 Glycolic acid is stated in msds Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419174 Share on other sites More sharing options...
April 7, 201312 yr comment_419791 I've actually been trying the lemon juice approach in my ultrasonic cleaner lately. Been using that on some motorcycle carbs. Carbs came out cleaner than when I put them in. But not as clean as I was hoping. That said, they seem to work just fine and my bike is back up and running. As most motorcycle carbs were made from aluminum you need to be a bit careful about which acids you use to clean them. As for my '78 280Z, that has a Holley 4bbl that needed a good cleaning after sitting for a few years. Lemon juice seemed to work OK on that one. At least the car seems to run fine. Well, a lot better than it did before I cleaned the carb (and installed a carb rebuild kit). Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-419791 Share on other sites More sharing options...
April 10, 201312 yr comment_420112 I rigged up a baking soda blaster with stuff I had laying around. It cuts right through the carbon deposits. Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-420112 Share on other sites More sharing options...
April 10, 201312 yr comment_420116 [ATTACH=CONFIG]62463[/ATTACH][ATTACH=CONFIG]62464[/ATTACH] I rigged up a baking soda blaster with stuff I had laying around. It cuts right through the carbon deposits.I bought an abrasive blaster at Tractor Supply. I just have to get around to trying it out.By the way, Blue, what did you and the good Captain find out when digging through the flattops? A friend gave me another set recently. Link to comment https://www.classiczcars.com/forums/topic/44249-lemon-carb-cleaning/?&page=2#findComment-420116 Share on other sites More sharing options...
