Posted August 30, 201212 yr comment_400178 Hello guysThis evening while driving the Z my gauge stopped working. I drove it the five blocks home and started investigating what exactly went wrong. Long an behold the single wire that goes to the temp sensor (the one for the gauge clearly) broke apart. Clearly the years have not treated this wire well. Question is, does anyone know what end one must use to connect to the water temp sensor. I tried using regular butt connectors (i have 100's at my house) but none of them worked well. Any help would be great.ThanksJan Link to comment https://www.classiczcars.com/forums/topic/44253-temp-sensor-wire/ Share on other sites More sharing options...
August 30, 201212 yr comment_400214 http://www.vintageconnections.com/Click on the "Place an order" link, then scroll down to "section 2". I believe you need their3.8 mm barrel connector part SS2.Get their RTL crimping tool as well. Great qualiy and reasonably priced at $39. Edited August 30, 201212 yr by zKars Link to comment https://www.classiczcars.com/forums/topic/44253-temp-sensor-wire/#findComment-400214 Share on other sites More sharing options...
