I have a triple weber carb setup that I will never be installing on my car. The setup came with my car when I bought it about a 1 1/2 yrs ago. Don't have any history on them nor do I know their value. Make me an offer if interested. I am attaching a few pictures for you. This setup came off of an early 74 260z. PM or email me if interested and I will try to answer your questions. I can send more picts too but I will attach 4 or 5 now.
https://www.classiczcars.com/forums/topic/4435-weber-carbs/
By what I've read and seen in pics look on the top of the carb under the wing nut ( Like in you closeup pics WEBER is above the nut ), There should be some number and letters stamped there, like 40 or 45 DCOE or the like
https://www.classiczcars.com/forums/topic/4435-weber-carbs/#findComment-24635
Yea, thanx. They should be 40mm throttle bores. I have some Dellortos that are the same. Would like to have 44 or 45s if I can find some in my budget. (That's always the trick, ain't it!LOL ) Or might just stick with the SUs, don't know yet. Thanx for the info.
https://www.classiczcars.com/forums/topic/4435-weber-carbs/#findComment-24715
