I was running through my wire harness today to check and see what connectors need to be cleaned or replaced. Well I found that my water temp sensor one of the wires was completely off of it with only one connected, after pulling it off gently to look at it closer the other wire came off. So my question is how do i pull the connector pins out so i can re connect and solder the wire back in?
https://www.classiczcars.com/forums/topic/44371-water-temp-sensor-connector/
I don't know if the terms i am using are correct or not. But the clips from the harness that connect to the various sensors, some are two wire and three wire. I need to know how to pull the metal clips out of the plastic piece that pops into the sensor so i can reconnect the wires. I'll try posting a picture.
It's the same type of connector as used on the injectors, so if you can find a write-up or post on that, it will be the same. I know that Fric Frac has written a tutorial and posted a video over on Hybridz, for installing the upgraded connectors he was selling. I think that you have to slip a small screwdriver or pick down behind the wire to hold a metal clip back, while pushing the pin in, then pull the pin out when the clip is clear
