October 23, 201212 yr Author comment_404977 OK. In an effort to just have "something", I went to a local muffler shop and they installed a stock-looking round muffler that is a little larger than the original (they said everything else was OK). It is too quiet. It sounds like a Prius. Well, maybe not that quiet. I'm going to live with this for a while and see if I like it. Link to comment https://www.classiczcars.com/forums/topic/44410-what-is-the-most-stock-sounding-exhaust/?&page=3#findComment-404977 Share on other sites More sharing options...
October 23, 201212 yr comment_404978 I've got 2 stock exhaust systems that are almost like new.....one with 36,000 original miles. I tried to get them to MikeB, but they're too big to ship. $125.00 each to anyone that can pick them up......if that helps. Each has all parts from down pipe to tip. Guy Edited October 23, 201212 yr by Diseazd Link to comment https://www.classiczcars.com/forums/topic/44410-what-is-the-most-stock-sounding-exhaust/?&page=3#findComment-404978 Share on other sites More sharing options...
December 5, 201212 yr comment_408445 Guy - a quick question for you - what exhaust systems do you use on your beautiful Zs ?? thanks Link to comment https://www.classiczcars.com/forums/topic/44410-what-is-the-most-stock-sounding-exhaust/?&page=3#findComment-408445 Share on other sites More sharing options...
December 5, 201212 yr comment_408448 Here is my muffler a Flowmaster............deep sound Link to comment https://www.classiczcars.com/forums/topic/44410-what-is-the-most-stock-sounding-exhaust/?&page=3#findComment-408448 Share on other sites More sharing options...
December 5, 201212 yr comment_408450 kjohnson2444 said: OK. In an effort to just have "something", I went to a local muffler shop and they installed a stock-looking round muffler that is a little larger than the original (they said everything else was OK). It is too quiet. It sounds like a Prius. Well, maybe not that quiet. I'm going to live with this for a while and see if I like it. If you decide you do not like it and a 2.25" dia. system is in your future, I have a Borla stainless steel muffler available at a very reasonable price. See the attached drawing for dimensions. It has one little problem. A tech mistakenly welded a flange on the discharge end. The flange just needs to be cut off and a tip added. If you decide to go with a 2.50" dia. system, I also have Borla S.S. components available for a complete system. The muffler dimensions are the same as the 2.25" muffler. The 2.50" system is available as shown in the photo or as individual items. Fixitman Borla-Muffler40652.pdf Link to comment https://www.classiczcars.com/forums/topic/44410-what-is-the-most-stock-sounding-exhaust/?&page=3#findComment-408450 Share on other sites More sharing options...
May 30, 201410 yr comment_448812 kjohnson2444 said: My original exhaust is sorely in need of replacement. Is there a muffler and pre-muffler available that replace the original with a stock look and sound?I don't remember what the stock exhaust sounded like (I did own a '73 in '82!), but on a 2.5" exhaust, I just put a "Meineke" 24 inch resonator (4024005S, $60) just aft of the headers, and a Flowmaster (12514310) DBX Muffler in and it sounds absolutely awesome. Not very loud at idle or when not pushing it, but gives that wonderful sound under load. I highly recommend this combination!The resonator has a spiral of curved scoops inside, and we installed it with the scoops grabbing into the flow. They said that gives a little more dampening, and that is what I wanted... btw, Meineke did an excellent job of bending pipe and welding - all for $180. I supplied the Flowmaster from Amazon ($150).Stephen Link to comment https://www.classiczcars.com/forums/topic/44410-what-is-the-most-stock-sounding-exhaust/?&page=3#findComment-448812 Share on other sites More sharing options...
