Posted September 18, 201212 yr comment_401977 Ok it's time for me to order the weatherstrip kit. who has the best and most complete kit? looking at black dragon looks like it is a little cheaper but missing some for the door. or is the MSA kit more complete? thanks for your help guys. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/ Share on other sites More sharing options...
September 18, 201212 yr comment_401981 Only a side-by-side listing of the component parts of the two kits will answer your question. You will still end up purchasing a few items individually no matter which one you go with. Be advised, unless otherwise specified, both sources get their components from Precision Replacement Parts (PRP). The PRP items are generally nice products but have a history of poor fit for the doors, windshield, and hatch glass. The genuine Nissan parts for the doors, windshield and hatch glass are still available and have a perfect fit. Kia Sportage door gaskets have also been used on S30 Z's with excellent results (I have them). Vintage Rubber makes excellent replacements for all items, they are pricey. Search the forums and you will find a wealth of info on this topic. Good luck. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-401981 Share on other sites More sharing options...
September 19, 201212 yr comment_402017 I bought my door seals at a Nissan dealer using the part numbers from the CD that this site sells (or used to sell).They fit perfectly. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-402017 Share on other sites More sharing options...
September 22, 201212 yr comment_402319 About a year ago I bought some after markets - regretted it from day one. Removed them and bit the bullet for OEM Nissan (as Walter stated above) and I have never regretted it since. The doors close easier AND CORRECTLY and the road noise was less - well as least as can be on a 40+ year old thin sheet metal car Jim is right --- Go with OEM on Doors, Windshield and rear hatch - if you have to skimp on the others then you must, but remember OEM works best. Hope this helps. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-402319 Share on other sites More sharing options...
November 6, 201212 yr comment_406219 Can you guys confirm that this (insane) price for OEM door strips is correct?http://www.courtesyparts.com/240z-260z-280z-parts-s30-1970-1978/weather-stripping/-c-7724_7754.htmlAlso the discrepancy between left and right door seal prices?I need them.. but Im just a little dizzy after seeing the $$$$Edit: just noticed its for a 2+2 apparently. Anyone have a part number for 74 260z door seals? Reasonable price? Edited November 6, 201212 yr by thedarkie Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406219 Share on other sites More sharing options...
November 6, 201212 yr comment_406237 The last door seals I purchased last year - were the two last one's in the Country for a 73 240Z. Courtesy had one and a Dealer in California had the other. As I recall they were around $500.00 total, plus shipping. That was for Seals with the new Pinch Welting attached.You are lucky if any for the 260Z's are actually still available. At this point $500.00 for both of them seems reasonable to me..The last OEM NOS rear window Seal I had installed - split from age within a year. Now it has to be replaced again..FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406237 Share on other sites More sharing options...
November 6, 201212 yr comment_406238 I bought my door seals at a Nissan dealer using the part numbers from the CD that this site sells (or used to sell).They fit perfectly.Couldn't find the CD with the parts numbers here. Can anyone direct me to a place to buy it? Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406238 Share on other sites More sharing options...
November 6, 201212 yr comment_406253 The last door seals I purchased last year - were the two last one's in the Country for a 73 240Z. Courtesy had one and a Dealer in California had the other. As I recall they were around $500.00 total, plus shipping. That was for Seals with the new Pinch Welting attached.You are lucky if any for the 260Z's are actually still available. At this point $500.00 for both of them seems reasonable to me..The last OEM NOS rear window Seal I had installed - split from age within a year. Now it has to be replaced again..FWIW,Carl B.Thats disconcerting.. Both the price, and the fact that your OEM strips cracked after only a year. Im going to call Nissan Canada when I get home today, but can someone recommend an aftermarket complete seal for the doors? The ones I have in place were butchered by the previous owner (and further by me) in an attempt to get the doors closing properly.Which company makes the best, most oem-like strips? Vintage Rubber looks promising but I havent heard any first hand account of door seal fitment specifically. Edited November 6, 201212 yr by thedarkie Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406253 Share on other sites More sharing options...
November 6, 201212 yr comment_406274 I bought the complete kit from MSA (PRP) and like the others mentioned, its not a perfect fit. The new kit is better than what i had but yea its not great. The other smaller pieces all seem to work fine. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406274 Share on other sites More sharing options...
November 7, 201212 yr comment_406323 I have bought from MSA and Vintagerubber, latter is definetly 100% better quality. Prices might be bit high but they are worth every penny. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406323 Share on other sites More sharing options...
November 15, 201212 yr comment_406889 Les at Classic Datsun Motorsports has another manufacturer. Check with him as well... Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406889 Share on other sites More sharing options...
November 15, 201212 yr comment_406895 I have to ditto on the MSA door pieces. I bought and installed them in 2000 and the first time you see water leaking in you are definitely not happy. The door never closed properly either. I am going to spend what it costs to have it like it should be. I have read some happy results by those that used the Kia part. Link to comment https://www.classiczcars.com/forums/topic/44441-weatherstrip-kit/#findComment-406895 Share on other sites More sharing options...
