Posted September 23, 201212 yr comment_402413 My 280z ac condenser is black, but a lot of the paint has chipped off with time. Can I LIGHTLY media blast the condenser and repaint it? If read this affects cooling. Would you use normal paint? Link to comment https://www.classiczcars.com/forums/topic/44484-painting-ac-condenser/ Share on other sites More sharing options...
September 25, 201212 yr comment_402547 Can I LIGHTLY media blast the condenserThere's no way I would ever blast a condesor with anything. Lightly or not.I'm no A/C expert, but since you didn't get any other responses... Link to comment https://www.classiczcars.com/forums/topic/44484-painting-ac-condenser/#findComment-402547 Share on other sites More sharing options...
October 2, 201212 yr comment_403148 You could lightly paint it, but no sanding. You could use a soft wire brush and wipe down the fins to remove loose debris. Link to comment https://www.classiczcars.com/forums/topic/44484-painting-ac-condenser/#findComment-403148 Share on other sites More sharing options...
