you should search for EFI and ITB. The VicZcar has a great write up. There are also bolt-on solutions from japan. If you must know, you need ITB, manifold, injectors, stand alone etc.
it will cost WAYYY more than a set of mikunis with a Kameari manifold.
I would suggest you contact Eiji at www.datsunspirit.com as well. He will have more information on this as well, as I think his orange car runs this set up.
He does whole lot more than just build engines!
