Email logins are now active ×
Cams with long duration but smaller lift?
Jason240z
Howdy all.
I've a cam
300/300 duration
valve lift 0.453" inlet
valve lift 0.451 exhaust
Timing inlet open 43btdc closes 77abdc
exhaust open 77 bbdc
closes 43 atdc
Full lift 107 deg atdc inlet btdc exhaust
Am I right in thinking that the lift is a little low? Reading the specs it reads like it should be a nice 4-7000rpm grid, or have I missed something!?
Its going in a 2.4(+1mm) 40mm carbs, proper exhaust, modded e88 with large valves and skimmed etc.
Check the information on http://www.xenons30.com/cams.html. See Comp cams at bottom of page. They come close to what you have. One thing is certain, its not for normal street use. Duration is to long for that. Its more a performance street cam. The long duration and low Lift makes it suitable for standard springs and reduces valves float at high revs.
One thing Ive learned over time is when deciding between two cams (for street use) always go for the milder cam. I dont know what cam you are now using, but if its close to standard you will have to change your driving style with this cam.
Edited by EuroDat
  • Who's Online   1 Member, 0 Anonymous, 414 Guests (See full list)
