Is there a source for interior RED paint, can spray type, I need(actually want to)retouch/repair some minor sun damage on my door panels, any info/tips welcome ;)
Edited by 72 OJ
I think I used SEM vinyl dye for my interior and it was an exact match. The shock towers had faded to nearly white!
Chuck
SEM is the ticket. A place called Tabco sell paint supplies in Houston (not much help in Fulton, sorry). You can try:
KolorPro
1129 Somerset Avenue,
Beltsville MD 20705
(301) 595-9183
OR-
FinishMaster
5049A Branchville Rd.
College Park MD 20740
(301) 474-3200
As with all painting, the work is in the prep. I used SEM on part of my door panels and was happy with the result. They sell a prep solution, but I used Acetone.
It is very important that you clean off any oil/silicone/treatment that has been rubbed onto the vinyl, or the spray paint will not stick.
I used SEM on the back seat of my 1929 Ford Roadster - be sure to use the Prep/Cleaner - use it with good ventilation. Once you apply the color you can not scrape it off - it is really a dye, not an interior paint. Highly recommend it to anybody just so you do the prep/cleaner correctly.
NAPA Red is a SEM Color Name - I don't know of the NAPA Parts Stores sell it or not.{just wanted that to be clear}
SEM products are handled by most Automotive Paint Stores and suppliers.
FWIW,
Carl B.
