November 2, 201212 yr comment_405921 jharvat -- Great to hear you're pleased with the results of AD. Can you please let me know how much they charged for the rebuild service as well as the turn-around time? Thanks. Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-405921 Share on other sites More sharing options...
November 2, 201212 yr Author comment_405930 For my particular distributor, they charged $200. But they returned to me a little jewel - it makes the rest of the car look bad. Turnaround time was about 2 weeks from my mailing it to them to me getting it back in the mail - so pretty quick considering the quality of work done. Gary - thanks for the advice on the ground wire. As you say, it couldn't hurt to ground it. Edited November 2, 201212 yr by jharvat Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-405930 Share on other sites More sharing options...
November 6, 201212 yr Author comment_406260 OK, now back to my usual dumb questions. Where exactly did the vacuum control hose originally run - from the distributor to... where? My thought is that it probably attached to the stock intake manifold someplace, but I've got a triple Weber setup on the car so I need an alternative spot to make the connection (short of running the hose all the way to the rear section of the intake manifold, which is where the previous owner had put it). Any ideas? Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-406260 Share on other sites More sharing options...
November 6, 201212 yr comment_406266 Connect to behind the front SU carb. Edited November 6, 201212 yr by tamo3 Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-406266 Share on other sites More sharing options...
November 6, 201212 yr comment_406270 OK, now back to my usual dumb questions. Where exactly did the vacuum control hose originally run - from the distributor to... where? My thought is that it probably attached to the stock intake manifold someplace, but I've got a triple Weber setup on the car so I need an alternative spot to make the connection (short of running the hose all the way to the rear section of the intake manifold, which is where the previous owner had put it). Any ideas?Triple Webers don't have a ported vacuum source, that's a hose to nowhere. You could try using the vac advance referenced to manifold vacuum but don't expect the results to be great. You'll likely end up with static timing too retarded, thus limiting WOT performance. FWIW, tailoring a spark-advance curve to an engine is not trivial. Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-406270 Share on other sites More sharing options...
November 6, 201212 yr comment_406276 According to http: //datsunzgarage.com/engine/ triple Webers run better when you do not use the vaccum advance. This is probably why yours was not connected. Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-406276 Share on other sites More sharing options...
November 6, 201212 yr comment_406277 According to http: //datsunzgarage.com/engine/ triple Webers run better when you do not use the vaccum advance. This is probably why yours was not connected.Don't quote that site, there are tons of misconceptions in there, especially the Weber section. Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-406277 Share on other sites More sharing options...
November 8, 201212 yr Author comment_406362 DJ, turns out you are correct. Advanced Distributor also recommended that I not hook-up the vacuum advance with the triple Webers. So, I will just leave well enough alone. Link to comment https://www.classiczcars.com/forums/topic/44598-rebuild-a-distributor/?&page=2#findComment-406362 Share on other sites More sharing options...
