interior panels?
JacktheRiffer
EScanlon is right. I looked for two years. New ones, yes new ones come up. Usually one at a time. One, just recently, but it was a 280Z 2+2. I have a 'good' condition passenger door in red. The chrome has come off but I could dye it black for you. Contact me off line by PM if you're interested.
Then why not make your own?
There is a template for the backing for download in the forum showing you dimensions, cuts and hole placements for the board. You could make it out of some ABS or TFE plastic so as to avoid the moisture absorbing problems of particle board.
As far as the vinyl covering, if all you want is to cover the board, simple vinyl, leatherette or other ... whatever.... is up to you. Don't listen to those who would criticize it for not being original or to their taste, it's YOUR car, and more to the point, it's YOUR budget. If they feel bad enough about it, they can contribute to your fund to restore it to stock.
Replacement skins are available WITH the chrome strip, but again, you'll be spending some money and still having to come up with the backing, whether by making or re-using.
But if you decide to go it custom, the key is to be careful and produce a quality product and not something cheesy.
So if perfect panels aren't a priority, then do check the classifieds, put a "Wanted" ad, and check e-bay and Craig's list, they're out there. Most expensive will be the shipping.
FWIW
E
