240z gas tanks
nahurry
If you go the restoration route make sure both supply lines still work when you get it back. I "assumed" my tank was correct.... drove me nuts.. deinstalled tank again only to find the gas supply line was sealed closed inside the tank.
Aircraft paint remover carefully applied fixed my tank.
  • Who's Online   1 Member, 0 Anonymous, 765 Guests (See full list)
