synthetic oil ?
zhead240
I have been using Valvoline VR1 in my engine because it has a higher level of "zinc" which is good for old style engines. So Im told.
See http://www.valvoline.com/faqs/motor-oil/racing-oil for info. Its a conventional oil for racing, but also for street use.
I had synthetic before I changed over. The shop said they did not mix very well. When I changed over I drained it overnight, filled it with 3 ltrs of VR1, ran it for 10 to 15 minutes to mix the oils good and drained it again overnight. Then filled it up with VR1.
  • Who's Online   1 Member, 0 Anonymous, 849 Guests (See full list)
