I have been using Valvoline VR1 in my engine because it has a higher level of "zinc" which is good for old style engines. So Im told.
See http://www.valvoline.com/faqs/motor-oil/racing-oil for info. Its a conventional oil for racing, but also for street use.
I had synthetic before I changed over. The shop said they did not mix very well. When I changed over I drained it overnight, filled it with 3 ltrs of VR1, ran it for 10 to 15 minutes to mix the oils good and drained it again overnight. Then filled it up with VR1.
i ask because the p o of the tr6 said it had synthetic oil if i remember correctly. also i'm told you don't have to change synthetic oil as often. what's the recommended mile between changes.
