Posted October 24, 201212 yr comment_405123 I got my z almost 6 months ago since then i have made afew changes. heres a bunch of pics of what i have done so far. i will add when i do more to it. this is when i first got the car. i got it from boston mass, it came from texas so has no rust. when i got it it had carb problems and would not go past 70 on flat high way and would not go past 30 up hills. I fixed all the dry rotted hoses first, then added the body parts and it needed new struts badly so i ended up lowering it in the process. at the same time i replaced the break booster and master cylinder. i also fitted a 240z grille in. i changed out some interior parts from a parts car. then i traded some parts for a header. once i had a spot in the garage i pulled of the header and carbs. rebuilt cleaned and painted everything. also i ported the intake a very little bit. after that it ran perfect. when i pulled the old header off a few of the studs were broken off and about half the bolts were loose. and the gasket had silicone on it! but long story short i was able to fix it all. the most current pics are the ones with the slotted mags. i got those off a 240z parts car i got, i was just waiting on my lugs. im 16 and this is the car i have spent the most time on. i've done all the work by myself. i love driving it, especially to school kids always ask me what kinda car it is and give me complements. thanks for looking! Edited October 24, 201212 yr by Searsgremlin Link to comment https://www.classiczcars.com/forums/topic/44755-my-260z-project/ Share on other sites More sharing options...
October 24, 201212 yr comment_405124 Looking good, clean body and nice stance............congrats . Link to comment https://www.classiczcars.com/forums/topic/44755-my-260z-project/#findComment-405124 Share on other sites More sharing options...
October 26, 201212 yr comment_405343 Nice ride! When I was 16 I drove a Vespa scooter, my how times have changed, but then I'm about 4X older, keep up the good work. Link to comment https://www.classiczcars.com/forums/topic/44755-my-260z-project/#findComment-405343 Share on other sites More sharing options...
October 26, 201212 yr comment_405370 Nice ride! When I was 16 I drove a Vespa scooter, my how times have changed, but then I'm about 4X older, keep up the good work.Looks great! When I was 16 I rode the bus xDMy Z is my first car, but I wasn't lucky enough to find it until this July, just after I turned 19. ;P Link to comment https://www.classiczcars.com/forums/topic/44755-my-260z-project/#findComment-405370 Share on other sites More sharing options...
