June 9, 201311 yr Author comment_425190 haha yeah, it's damn unmotivating when it rains all the time and is cold, that's probably one of the main reasons progress hasn't been to big this year, but im happy we now have sunny and warm so i keep going to the garage whenever i can Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-425190 Share on other sites More sharing options...
June 12, 201311 yr Author comment_425440 Spent some time in the garage today and had some nice progress: 1) Removed the wiper motor and windshield squirter stuff: 2) next adress was starting preparation of the dashboard removal, so started with the wiring stuff, and screws, dashboard is loose now but still need to disconnect a few wires and the speedometer-cable, etc.. Oh and also removed the shifter boot **: this is how i ended up today: Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-425440 Share on other sites More sharing options...
June 13, 201311 yr comment_425513 Hi Niels, Nice to be making progress again. Can't see it in the photos, but I trust you are bagging all the small parts for later.It all looks logical now, but six to twelve months down the track you'll be scratching your head wonder which bolts,screws do I use the fit that???Chas Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-425513 Share on other sites More sharing options...
June 13, 201311 yr Author comment_425540 Well yeah i put stuff like screws into small plasticbags and tie them to the holes they belong to. I plan to replace most of them anyway but this way i know which screw belongs where. i also have a box with screws where i document where they belong.. should make it a lot easier later. tho i still think i will need to do a lot labour when assembling stuff again Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-425540 Share on other sites More sharing options...
June 16, 201311 yr comment_425726 Keep going, that's the most important part in getting it done ! Good luck . Gr Bart. Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-425726 Share on other sites More sharing options...
July 9, 201311 yr Author comment_427258 Had a little time with the fairlady again today and after an hour of disconnecting cables, wires and hoses i finally got the dashboard out: here it is: and had some time left so i also removed the blower and started to remove the heater: Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427258 Share on other sites More sharing options...
July 9, 201311 yr comment_427262 Making good progress. The dash looks ok compared to the stuff under the car. Its looks only really really grotty. Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427262 Share on other sites More sharing options...
July 10, 201311 yr Author comment_427294 EuroDat said: Making good progress. The dash looks ok compared to the stuff under the car. Its looks only really really grotty. Well also might be the lighting and my bad pictures, but in reality the shell and subframe aren't too bad Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427294 Share on other sites More sharing options...
July 10, 201311 yr comment_427297 Hi Niels, Your photos are not bad at all. Its an excellent thread to follow because of the photos:cool:I was comparing your slave cylinder in post #101 and the heavy surface rust on the rear suspension in post #102. They are all signs that the car has been standing for a long time and probably out in the sun and that can be hard on dashes.My dash has some serious cracks in it (under a dash cap) and its spent the last 20years in the back of a garage.Looking at that suspension made me think of something else: spindle pins. Yours might be a real PITA to get out. Have you started spraying the spindle pin with WD40? A mix of acetone and auto tranny fluid is highly recommended by other members and I agree:bulb: You could brush that in them before trying to get them out.Cheers Chas Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427297 Share on other sites More sharing options...
July 10, 201311 yr Author comment_427300 aaah, now i understand well the good thing is i have allready a completely powdercoated suspension setup with ne tokico shocks, and stuff laying around from the first shell which i've prepared already, so no need to restore or take apart the rusty stuff from car number two I also got new spindle pins, bearings and a lot more (had to destroy the spindle pins on removal at car nr. one, check my blog at JDMjunkies.ch | JDM streetlife Switzerland for all the pain of spindle-pin removal ): and of course i got the energy bushings master bushing kit (plus a few extra bushings): and then a set of rocky auto doglegs: and Nagisa Auto / NAMS tierod endlinks (all adjustable): as well as a lot more parts. only parts missing "below the chassis" are new engine-, transmission- and differential-mounts, springs and the brake-parts. Everything else i already have refurbished or restored from chassis nr.1 and ready for beeing isntalled Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427300 Share on other sites More sharing options...
July 13, 201311 yr comment_427550 Thats a great old workshop your grandfather had. A treasure of old cars:love: Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427550 Share on other sites More sharing options...
July 17, 201311 yr Author comment_427858 At this point i have to thank my big friends Manuel and Stefan for the non-stop support of my project! Big thanks, guys! They lately went to Japan and visited some shops (Kakimoto, Rubber-soul, Rocky Auto, NISMO,..) and thought they'd bring something for me. So at one point i got a message they bought some cool stuff for me. and finally today a package showed up in my mailbox and i can't be happier: 1) a geniuine G-Works Magazine (S30Z Fairlady special Nr.2 (I already Own Nr1 )): It's like the HyperRev magazine for classics. Lot of parts information, Links,... Detailed description of mechanics and stuff... Kind of the Holy bible for tuners and fans And then they also bought me this pretty heavy Metal Fairlady Z Emblem, brand new and pure bling. Absolutely love it! Thanks again guys, can't thank you enough Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=10#findComment-427858 Share on other sites More sharing options...
