March 8Mar 8 Author comment_675193 I'm having a good pace currently and making some small progress almost daily. Currently, I'm test-fitting all the items so that they can go back to the bodyshop for final adjustment and panel-gap correction etc.The first thing I wanted t install were the rear quarter windows, but I quickly realized that some areas needed rework. Some time in the history of this Z, someone bent one of the mounting brackets heavily, so I had to get it straight again... And after spending 2 hours or so fixing various small details, the rear quarter windows finally went in, and fit perfectly:While working on it, i noticed the doors didn't fit properly. The reason? The door locking mechanisms were not installed. So the door was either not closed properly, or pushed too much inside.Before:And after. To get the mechanism in, i had to remove the upper door window frames out again. But that was a quick task. And on the opposite side, the locking counterpart went in. So now the doors can lock secure, are in the correct position for panel gap and body-line adjustments and are also safe for transportation and moving around, without the risk of the doors open by themselves.Next i got a bunch of O-rings and circlips for the rear differential, stub axles, handbrakes, etc. which were recommended to me by @Mymechanics (Great YouTube channel, if you haven't checked it out yet!)The next steps are already in preparation, I got some upgrades for my Workshop and have some more parts on the way, so stay tuned for another update soon Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=75#findComment-675193 Share on other sites More sharing options...
March 13Mar 13 Author comment_675288 I've collected some parts again recently, so it's time for another update full of random bits and pieces.Reader RIP260Z pointed out that the Pump diaphragm is missing in the American Mikuni rebuilt kits which I got recently, but are included in the Japanese Mikuni rebuild kits. Luckily, I was able to find a guy in Japan who sells all OEM Mikuni / Solex parts individually, and I ordered plenty of parts, that were still available - Including the Pump diaphragms and many wear and tear parts like springs, etc.Speaking of Mikunis, I also found an original Japanese Solex NPHH44 service manual. I had a Copy of it before, but this is an original one, which is very nice to have :-)And on the left side, you can see an original German PHH44 manual. This is a completely different manual for the original Solex PHH44. Those were used on the NSU TT and TTS and the BMW E10, 2002, etc. if I'm not mistaken. The manual is quite useless, as the NPHH44 Mikunis / Solex don't have too much in common with these, but nevertheless it's cool to have a reference to the "original" design of these, with some German explanations.The explanation of the working principle in the German book is really cool, with all those hand-drawn graphics.The biggest part of the various deliveries was this Center console:It's made by VintageDashes in the USA. After he explained how he made it and so on, I decided to give it a try, despite the big price-tag. So far it looks very promising, but i have to check the details. I will compare it with the OEM console and the one from ResurrectedClassics which i also have in stock, soon.I found another Datsun Switzerland pricelist. This time from February 1978. As usual, I scanned them all in high-resolution, and you can download my whole collection here, for free.And then another useless, but cool part. The Eaglemoss-spareparts box. Which belongs to the kit, but sadly was missing in my set.If you want to know more about the eaglemoss 1/18 Fairlady set --> read here, and here. Aside from 2 empty binders (for the magainzes) and the original tool-pouch, my set is pretty much complete, now :-)I already have the next bunch of parts waiting in Japan, a delivery from Nissan directly, and I've worked a bit on the car too and did some research, so you can expect more updates again in a few days.Oh, and I also got a free heavy-duty grinder for my workshop, and cleaned / restored it a bit this week. If this is your kind of thing, then read the full story here. Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=75#findComment-675288 Share on other sites More sharing options...
March 19Mar 19 Author comment_675353 Yesterday I got another bunch of NOS parts for my project, straight from the Nissan Stocks:Fuel tank sensor / sender Mounting ring and O-ring, plus the timing cover gasket.Front and rear bumper rubbers, Inspection lid foam rubber pieces and rubber sealsVarious spark plug wire bracketsHood bumpers, Hood stoppers and inspection lid rubber bumpersWindow crank fasteners, Engine tube hose clamps and some heater panel knobsAnd last but not least, I also got a Swiss 260Z 2+2 brochure, which i for whatever reason didn't have in my collection yet:I also did some actual work on the car again, so stay tuned for another update, soon. Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=75#findComment-675353 Share on other sites More sharing options...
March 24Mar 24 Author comment_675416 So, I have been busy test-fitting various parts on my Z again.To set the alignment of the hood and fenders properly, I had all the hood hardware spacers, dampers and rubbers installed.Next on the to-do list was the rear hatch damper, so I can work on the hatch without having that temporary wood rod as a not-so-safe hatch holder. Wile both dampers I had were still working nicely, the mounting brackets were worn out on both and both had missing or cracked plastic / Teflon spacers.So after I got everything straight and assembled a temporary setup (I still need to find a good set of those plastic spacers).I finally had it all installed. Works perfect.It seems like that little-bit of extra-tension from the damper is required to have the hatch aligned properly with the roofline. I didn't expect the damper itself would already fix the alignment, but I'm happy it does.Now I only need to finalize sanding on the trunk spoiler and bring back the holes for the spoiler emblems. I also need to find a good rear bumper to test fit it. Mine both had a decent hit and are way too wonky to use them for test-fitments.Then, some people were suspicious about that extra sheet metal on my transmission tunnel (I have the updated body version from 1972, but still the early A-transmission, so I suspect they added that sheet metal to cover the hole?). Even though it's the original transmission of this car, it made me want to test fit it, just to be sure it all fits, before i paint the shell. So i had to assemble parts of the transmission first. Mainly the gear selector with the shift rod mechanism.For simplicity, I only used the center section of my FS5C71A five-speed transmission, because that's fine to test fit it. So I added the transmission bracket with the rubber insulator to it.And installed (Bolts only temporary, as usual - please ignore).And here we go. I can shift in all directions without hitting anything. But it's still a bit close to the front. I need to check if I put the directional insulator between the transmission and the mounting bracket in the right direction.And since I had an original center console lying around from my recent center console comparison i put it in there, just for fun's sake. Even though it's all only temporary test-fitting, it's really fun and nice to see all the bits and pieces come together nicely.I have already prepared some next steps on the interior, so stay tuned for another update soon. Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=75#findComment-675416 Share on other sites More sharing options...
April 9Apr 9 Author comment_675593 I've been busy dealing with life recently, but that doesn't mean I forget spending money on more or less useless automobilia :-)First, the Japanese L-series Service manual. I have it in various language, but never had "the original" one from JP. And since it popped up for a reasonable price, I had to have it.Then i got another Datsun Switzerland price list. This time from April 1980.As usual, you can find all of them scanned in high-resolution for free download, hereSome may know my List of various Japanese L6 Intake manifolds, carb kits and Turbo / Surge tank kits. And thanks to a hint, I recently acquired this lovely Japanese printed ad from the very first FET / HKS Turbo Kit.You can read a lot about it in my Intake / Turbo surge tank post, here.Thanks to a hint from Mymechanix, i got a beautiful Differential strap. The originals are usually worn out, and this replacement belt from Aliexpress has the perfect fitments and dimensions. All other alternatives come either in a leather look or rubber, this one is much closer to the original design. Unfortunately the surface is glossy and has some prints on it (see the one on the left) so i will try to sand it down, to get as close to the original look as possible. Link to comment https://www.classiczcars.com/forums/topic/44860-my-two-swiss-s30z-fairlady-restoration-build-thread/?&page=75#findComment-675593 Share on other sites More sharing options...
