Thanks Alfadog,
I suspect that the chassis of this car was that of (sold over here) the Ford Fiesta which, coincidentally had a 'sport' version called an XR2. This was a 1.6 injection model with all the Ford wannabe 'go-faster' stripes etc. It made it and the Escort XR3 the most nicked cars at the time and young drivers' insurance, very expensive !
Sean
Hello Sean
i have some "z" competitors here but only for 1975
260z coupe $6974
260z 2+2 7707
alfa 2000gtv 8088
BMW 2002 8419
FIAT 124 sports 6889
PORSCHE 911 coupe 18,865
PORSCHE CARRERA 25,437
TRIUMP STAG 11,480
and the locals
VALIANT CHARGER 770 5914
FALCON GT 7103
FALCON GT 2dr 7231
TORANA SLR V8 5553
Cheers Roger
Originally posted by Alfadog
Do NOT buy a 90s crapi! They are one of the worst cars ever built - they continually have problems. There was a magazine article about the worst lemons of all time in Australia recently. The Capri rated number 1 if I'm not mistaken...
Funny that, since they were realy just ford lasers with different pannels, and they seem to have a good reputation. apart form weak gearboxes, especially the 4WD turbo laser. I completely destroyed my gearbox and center Differential. I always thought the 90's crappy were (still are) ugly.
:finger: "Mondeo" :finger:
Go wash your hand and your keyboard now, their must be some kind of rules against using word like that on this forum :classic:
I must admit your right, their is more than panel work to a car. My mum had a "Le Car" when we lived in Ohio, very far away from the Reanult 5 she had in France before, but you can't tell it from outside so!
But aren't we far away from Allan post here?
And a 260Z 2+2 is just a 240Z? And a X-type jag is just a Mondeo? etc. etc.
Dont go comparig 240z to 2+2 260z's.
A 240z is a beautiful car, the 2+2, on the other hand, looks like a deformed hunchback.
Ford owns Jag do they?
mazda 323 = Ford laser
Holden commodore = toyota lexan
toyota camry = Holden Apollo
nissan pulsar = holden astra
mitsubishi = (no one wanted to team up wih them)
blame the government at the time for thier idea to make the car market more competative by forcing car manufacturers to share models.
Here in the states mitsubishi and Dodge got togather. There are alot of cars that dodge sold that where mitsu. The stelth was a 3000GT the lazer was a eclipse and there are more. Chrysler cut away from mitsu in the mid - late 90s.
Originally posted by Sean Dezart
loose snip
BTW, I think that the choke(starter)lever is better angled for RHD than left but perhaps that's just how my fingers are bent !
When one thinks about it, this thread started with the handbrake position, however in reality, it begs the question about the entire centre console.
Was the handbrake left on the right for left hookers because Nissan would have to produce a different console?
Whislt its a minor point it really effects the outcome as we have seen.
Ergonomicly the choke is in the correct position for a RHD vehicle, but how does it feel in a LHD?
Good point Zedrally,
But if you look at the ORIGINAL console ( with Choke and Hand Throttle in the centre behind the gearlever ) it was much more symmetrical than the later ( choke only ) version.
Take a look at my earlier-posted picture from the Tokyo Motor Show stand of 1969. You can see that the main difference they would have had to engineer for the console on the earlier cars was just the cut-out or clearancing next to the brake handle itself.
I get the feeling that carguyinok is far closer to the truth ( if there is a "truth" to be told ) of the productionising of the Handbrake lever assembly as it relates to the shell than anyone else so far.
However, my experience of these bodyshells in stripped-down form ( although perhaps more limited than many of the people that have been posting here ) tells me that the bodyshell could have only got so far down the line as an indeterminate LHD or RHD base. At some point it was allocated either an RHD or LHD identity, and I think that point must have been when the FIREWALL was put into the car. From what I have seen of the LHD to RHD shell conversions in this country ( usually relatively rust-free USA cars that are converted using a rusty UK-market RHD car as a parts and identity donor ) I reckon that to do a "proper" and full job of the switch the WHOLE firewall panel would have to be switched. In reality, this very rarely gets done ( far too complicated ) and a compromise is made. Its relatively simple to do - but you can usually tell that its been done if you look closely.
As has been pointed out, some of the panels that made up the bodyshell must have been generically designed ( such as the top of the scuttle, where the wiper arm pivots go, having both LHD and RHD-type cutouts ) so that the pressings could be used for both versions. However, as far as I can see, the main part of the firewall ( not just the pedalbox support panel ) seems to be either LHD or RHD oriented.
As carguyinok has pointed out, maybe having a "handed" trans tunnel pressing would have meant that the orientation of the bodyshell would have had to have been determined further back down the line than ideal? That would seem to be logical.
Its still interesting that they chose to have the handle on the right
side of the tunnel, though.........
Anybody find those prototype pics interesting? I thought it was worth noting that they were ( perhaps naturally ) RHD-oriented.
Alan T.
Alan T.
Alan, in any of you literature is there an exploded view of the body shell?
I'm starting to form an opinion that it all based on the trans tunnel after all.
Mike
