Posted November 12, 201212 yr comment_406630 hi guys ive got a chance to pick up a set of of triple solex carbs with out linkages or manifold for 100 dollars [aus] is this a good price .also how hard would the rebuild kits be to get and are they expensive .thanks Link to comment https://www.classiczcars.com/forums/topic/44907-triple-solex-carbs-rebuild-kits/ Share on other sites More sharing options...
November 13, 201212 yr comment_406694 Good buy! Fun to learn and tune too... worth the $100 for the entertainment value alone. Link to comment https://www.classiczcars.com/forums/topic/44907-triple-solex-carbs-rebuild-kits/#findComment-406694 Share on other sites More sharing options...
November 13, 201212 yr Author comment_406705 do u think there a good carb.a mate has a set of su,s so i have that option as well Link to comment https://www.classiczcars.com/forums/topic/44907-triple-solex-carbs-rebuild-kits/#findComment-406705 Share on other sites More sharing options...
November 13, 201212 yr comment_406710 I read that solex's are french weber-like carbs that are not nicely machined but Mikuni apparently made Solex's under licence so if it is a Japanese Solex then it should be similar in quality to a Mikuni. I think that any individual sidedraft triple set-up will be better than twin SU's if jetted correctly. Hopefully a Solex owner will chime in.Some Links:http://www.rmcarburetors.net/http://www.mikunipower.com/phh01.htm Link to comment https://www.classiczcars.com/forums/topic/44907-triple-solex-carbs-rebuild-kits/#findComment-406710 Share on other sites More sharing options...
