hi guys ive got a chance to pick up a set of of triple solex carbs with out linkages or manifold for 100 dollars [aus] is this a good price .also how hard would the rebuild kits be to get and are they expensive .thanks
I read that solex's are french weber-like carbs that are not nicely machined but Mikuni apparently made Solex's under licence so if it is a Japanese Solex then it should be similar in quality to a Mikuni. I think that any individual sidedraft triple set-up will be better than twin SU's if jetted correctly. Hopefully a Solex owner will chime in.
Some Links:
http://www.rmcarburetors.net/
http://www.mikunipower.com/phh01.htm
