Anyone try the MSA aluminum driveshaft?
71Nissan240Z
Im considering an aluminum performance shaft since my slip yoke is no good.
Thanks!
Do you have any idea how much of a weight difference there is? If there is a significant difference then it might be worth it (in my mind). This is not a static component, it's rotating so there would be an added benefit. I have a feeling, though, that this is the type of component upgrade you make when you are going for a track car and have already tweaked everything else. If you do make the change please post some results. I'd be interested to know how it works out.
I would think the reduction in rotatonal inertia might have a bigger impact than the weight savings. Similar to a lightweight flywheel. Would be pretty easy to calculate. As mentioned above, it might not be the most bang for your buck.
I agree, the radius is relatively small, but they are also made of steel, and constantly accelerating / decelerating... My comment was simply that the weight savings probably has less impact than the rotational energy savings.
Either way, it's not even worth doing the calculations. Like I said, there are other items / improvements that will provide a better bang for your buck.
Julio, I completely agree. Just adding some extra info... ;)
  • Who's Online   1 Member, 0 Anonymous, 614 Guests (See full list)
