Posted November 25, 201212 yr comment_407624 Hi I'm new hear and i am restoring a 74 260z i have a few questions.1. How do I remove rust that is inside my engine block where the coolant passes by?2. Also any advice on how to remove rust on the body of the car? Other than sanding? Link to comment https://www.classiczcars.com/forums/topic/45007-how-do-i-remove-rust/ Share on other sites More sharing options...
November 25, 201212 yr comment_407626 I acid dipped a block in muriatic acid using a plastic garbage can.You can do the same but use "evaporust".ORtake it to an engine shop that can do similar. Link to comment https://www.classiczcars.com/forums/topic/45007-how-do-i-remove-rust/#findComment-407626 Share on other sites More sharing options...
November 25, 201212 yr comment_407628 I used a Winchester gun cleaning kit from Walmart after it was vatted at a machine shop. http://www.walmart.com/ip/Winchester-Universal-Cleaning-Kit-24pc/20595702. Worked great. Link to comment https://www.classiczcars.com/forums/topic/45007-how-do-i-remove-rust/#findComment-407628 Share on other sites More sharing options...
November 25, 201212 yr comment_407649 I helped a friend derusy an old engine block using the electrolytic method: http://www.rickswoodshopcreations.com/miscellaneous/rust_removal.htm Link to comment https://www.classiczcars.com/forums/topic/45007-how-do-i-remove-rust/#findComment-407649 Share on other sites More sharing options...
