The feed comes out a different spot on the sumi caliper which means the stock weird s shape Brake line doesn't fit. Needs pretty much 2 90s which I made a template out of wire. Was thinkin to take it to a brake place and get 2 made up?
That what everyone else does?
ok i just read that VT v6 calipers are a direct bolt on to the 240K strut?? that would seem alot easier and i can get a pair of them for nothing quite easily! this true?! or sumitomos still better?
Edited by tez240k
They look pretty big. I'll grab one this week and try a 14 inch rim.
I can't see te offset just lining up perfectly. Will find out tho
Edited by tez240k
