December 19, 201212 yr comment_409594 I tapped my head into M12 on #1 & , they were M10 and threads worn over time. I found everything at Nissan dealer and could get you the part #'s if you want. Seems like they were for the truck motor but worked good and could tork them down really good without loctite or orther thread lockers, the heat is too high. Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409594 Share on other sites More sharing options...
December 20, 201212 yr Author comment_409606 No problem, I've had the exhaust leak frustration, and the broken studs that had to be drilled out (thermostat housing) frustration, and paid a shop good money to remove a stud (one of the three for the flange to the pipe) and resurface the sealing surface (before I knew that undamaged manifolds are relatively easy to find). Did you check the manifold for straightness, across all of the ports, and good sealing surfaces on each one?Good to know that the Seafoam showed something, another trick for the tool box. Good luck.When I replaced the manifold gasket I put a straight edge to the manifold (Really long one) and it all seemed rather straight. Now on that note, this was before I did a bunch of hill climbs where my manifold glowed red afterword - I'm assuming this isn't a good thing to do to these. ThanksJan Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409606 Share on other sites More sharing options...
December 20, 201212 yr comment_409670 I tapped my head into M12 on #1 & , they were M10 and threads worn over time. I found everything at Nissan dealer and could get you the part #'s if you want. Seems like they were for the truck motor but worked good and could tork them down really good without loctite or orther thread lockers, the heat is too high.Cylinder head bolts are M10, intake/exhaust manifold threads are M8. Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409670 Share on other sites More sharing options...
December 20, 201212 yr comment_409677 I was talking about the exhaust studs on #1 and #6. They were M8's originally, I confused them with the 4 intake M10's in the center, sorry. I found my recepit and I am wrong once again, they're M10x1.25 studs with M12 deformed nuts. Edited December 20, 201212 yr by siteunseen Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409677 Share on other sites More sharing options...
December 20, 201212 yr comment_409692 I was talking about the exhaust studs on #1 and #6. They were M8's originally, I confused them with the 4 intake M10's in the center, sorry. I found my recepit and I am wrong once again, they're M10x1.25 studs with M12 deformed nuts.It's more likely to be M10 studs with M10 deformed nuts. Otherwise, they wouldn't clamp much of anything! Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409692 Share on other sites More sharing options...
December 21, 201212 yr comment_409746 Most likely. Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409746 Share on other sites More sharing options...
December 21, 201212 yr comment_409756 don't like this talk of deformed nuts Link to comment https://www.classiczcars.com/forums/topic/45171-the-dreaded-exhaust-leak/?&page=2#findComment-409756 Share on other sites More sharing options...
