Might be a silly question, but here goes.
Tail lights (whether JDM or export), are they able to be swapped left to right???
Just watching Import Monster for some JDM lights and am curious in case i can pick up a single light setup :angry:
Well.....it will with some work. You can easily remove the lenses and put them in your Aus housings. Check out my build thread, I had them apart, pretty easy really.
Does that affect how the lighting setup works then with reverse and the park lights?
My 240k GL manual doesn't seem to say ( that or I couldn't find it) and I can't read electrical diagrams at all -_-
I remembered seeing a thread about someone disassembling theirs and cleaning the lenses...should've guessed it was you adz
The wire looms are completely different for the AUS and JDM versions but it wont matter if you swap the looms. I've seen some cheap sets of lights going on Yahoo Japan though, what are you using as your search string?
Been using ケンメリ which i got off the ebay/internet search thread, i think Uras posted it.
Since i dont have a great pc i've been searching import monster useing an iPad and phone
