Dome LED Light
Yellow78
If you can insert the old bulb and it still works, you are making poor contact with the LED. I am assuming you bought one tha mimics the terminals of old bulb.
Mine is a tube with terminal caps with points on each end. Scratch the contacts with a fine sandpaper or steelwool.
I had no problem with the LED bulb I got from Superbrightleds once I turned the bulb around for proper polarity. Of course, I installed new door switches at the same time and cleaned the contact area for the switches to ensure good contact with the body.
  • Who's Online   2 Members, 0 Anonymous, 802 Guests (See full list)
