Recently Browsing 0
Forgive me if this post is a little vauge, the weather and lack of garage has made it impossible to do any real work on it..
The last time it drove wouldve been Sunday the 23rd. I got off work around 11pm, it started just fine, and I drove home with no problems. It was probably around 20-32 degrees, much like today, and to keep it running I am having to keep it choked (im sure thats a problem of its own with the carbs) . Anyway, out of curiousity, I turned off the choke, and the car slowly died.
The next morning, itd snowed like crazy. I went to get it started, and it wouldn't. I realized my choke was still off, so I pulled back the handle and it broke off
but the lever itself was fine. I checked the position in the engine, and it looked rohht, pushed it off again, and things seemed to move properly. I cranked the key, and it would crank, but nothing.. now, over the last few days, its been doing this, and now the starters not doing so hot, and it wont hardly crank. Sometimesitll just tun over 1-5 times. Im sure the initial problem has to do with the choke, and carbs, but I cant even try anymore, I dont want to burn out the starter. The weather is awful, and I dont have a garage. Keep that in mind with your suggestions. Any help is appreciated.
https://www.classiczcars.com/forums/topic/45242-73-240z-wont-start-d/Share on other sites
