Posted December 27, 201212 yr comment_410191 Hi everyone;Running an L28 in a Z car (1980 engine block, I believe) for road racing. Any recommendations for type/weight of oil? I don't know what the previous owner ran in the car. I'm considering going to Valvoline 20w/50, but I'd like your thoughts first. I'm also considering adding zinc if I can find it on the aftermarket. I believe the earlier cars preferred zinc and heavier oil weights. I know oil debates are largely opinion based, but still, your opinions are welcomed. Thanks! Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/ Share on other sites More sharing options...
December 27, 201212 yr comment_410198 20-50W Brad Penn Green oil (has extra zinc)In our 2.8L vintage 240 race car running 13:1 compression ratio and in my 3.2L stoker 240 street car running 11.5:1 crOil analysis after every change. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410198 Share on other sites More sharing options...
December 28, 201212 yr Author comment_410230 Very helpful. Many thanks! Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410230 Share on other sites More sharing options...
December 28, 201212 yr comment_410231 I getthe ZDDP Zinc additive at NAPA Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410231 Share on other sites More sharing options...
December 28, 201212 yr comment_410243 My zinc of choice is http://www.cam-shield.com/Bonzi Lon Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410243 Share on other sites More sharing options...
December 28, 201212 yr comment_410244 I like Valvoline VR-1 which also has high ZDDP. I get it at Napa. I run my Z for 24+ hours straight on the track in ChumpCar and I've have no oil related issues at all. I run straight 40 weight if the ambient temps are reasonable. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410244 Share on other sites More sharing options...
December 28, 201212 yr comment_410245 Something with zinc! I run Redline 40w synthetic. The Brad Penn is good also. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410245 Share on other sites More sharing options...
December 28, 201212 yr comment_410246 I also use VR1 and change it every 10 hours of track time. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410246 Share on other sites More sharing options...
December 28, 201212 yr comment_410279 You might also consider running a low oil pressure alarm on the track. I use one of these...http://www.longacreracing.com/catalog/item.asp?id=785&catid=11I substituted an 85dB siren for the light. If the oil pressure drops below 20psi on the track the alarm will sound. If I don't turn on my Accusump while on the track I get an alarm at every braking zone and hard corner. The alarm is the best $25 insurance policy I have ever purchased.https://www.cantonracingproducts.com/product/24-026/24-026----ACCUSUMP-2QT-NO-VALVE/If you are going to road race an L6 I would think about an upgraded baffled pan or an Accusump. If you don't already have one. Just my $0.02. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410279 Share on other sites More sharing options...
December 28, 201212 yr comment_410292 Brad Penn. # 1 rated oil by Isky Cams.Mike. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410292 Share on other sites More sharing options...
December 29, 201212 yr comment_410305 Brad Penn is one of the most popular oils in the air-cooled Porsche world. I like that it is available in more viscosities than many of the other high ZDDP oils. Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-410305 Share on other sites More sharing options...
February 10, 201312 yr Author comment_414573 Once the filter fills up, does it have a 6 quart capacity? Link to comment https://www.classiczcars.com/forums/topic/45251-recommendations-for-racing-oil-type-weight/#findComment-414573 Share on other sites More sharing options...
