December 31, 201212 yr comment_410477 Steve,since you are running in a stock rpm range, why not have the original damper rebuilt? I sent my damper to the Damper Doctor -that was years ago. He guarantees the damper for 3 years. He redoes the rubber and says the damper will exceed factory HP numbers and rpm. I don't see the need for a 10krpm damper.Side note: Glad to see a company supporting our cars-MSA- but they don't seem really check out the products they sell. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410477 Share on other sites More sharing options...
December 31, 201212 yr comment_410480 MSA, I could start a whole thread on how cheesy most of their stuff is. Bare minimum is what they strive for. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410480 Share on other sites More sharing options...
December 31, 201212 yr comment_410503 I bought two, one for me and one for a resto. The one for the resto is to go on in the spring after it is machined. I am not sure if it should now. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410503 Share on other sites More sharing options...
December 31, 201212 yr Author comment_410507 Does anyone know if the stock damper or the Euro damper mentioned above fails safe? One good thing about the Powerforce damper and the BHJ/Rebello unit is that when the rubber fails the inner and outer rings stay together. If this was not the case, and it failed on the track I suspect it would have gone through my rad or worse. I am hesitant to install a damper that would fly apart if the rubber fails. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410507 Share on other sites More sharing options...
December 31, 201212 yr comment_410515 Call the Damper Doc and ask Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410515 Share on other sites More sharing options...
December 31, 201212 yr comment_410536 I wish you guys had mentioned this stuff last winter, when I needed to get a new one for the '78. I had to install a used one from Rod's Datsun parts, but it looked very nice and the rubber was kinda new-looking. the old one had a chip where the key went and needed welding, and the rubber was starting to dry out.It might be nice to have a spare (stock style, with two grooves for the '78 a/c) to slip on sometime, especially if it's a little lighter.Come to think of it, I might still have the old one to rebuild. Can they also lighten it a little? The bad thing is the guy that repaired the engine retired a few weeks after my car was done. :disappoin Edited December 31, 201212 yr by TomoHawk Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410536 Share on other sites More sharing options...
December 31, 201212 yr comment_410550 ATI do a range of dampers? Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410550 Share on other sites More sharing options...
December 31, 201212 yr Author comment_410552 After spending some time on HybidZ and speaking to Dave Rebello I've come to the conclusion that ATI and BHJ dynamics make the best dampers for my application. Dave uses the ATI units on the engines he builds and he says that he has never had one fail. I decided to go with the NIS-REB-6-SP from BHJ. Dave recommended this model for a L30 or L32 stroker such as mine. He recommends NIS-REB-6 for a higher rev'ing application. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410552 Share on other sites More sharing options...
December 31, 201212 yr comment_410553 How much will that run you Steve? Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410553 Share on other sites More sharing options...
December 31, 201212 yr comment_410554 Steve, My car isn't 'exclusively' a track car, but the euro dampner has been on there for years and I wind it out pretty good. No problems. That aluminum one is not going to come apart. It's solid. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410554 Share on other sites More sharing options...
January 1, 201312 yr Author comment_410559 The BHJ unit cost me $385. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410559 Share on other sites More sharing options...
January 1, 201312 yr Author comment_410560 the euro dampner has been on there for years and I wind it out pretty good. No problems. I don't doubt that the euro dampers can take a beating but the euro units that are out there are getting old so if I went that way I'd want to have it rebuilt before I used it. I don't have time to start down that path as I have 4 vintage car races to run in the next 2 weeks. Link to comment https://www.classiczcars.com/forums/topic/45275-harmonic-damper-problem/?&page=2#findComment-410560 Share on other sites More sharing options...
