Posted January 8, 201312 yr comment_411255 I need the dimensions for the front crosmember holes and the distance from the very rear lower control arm mount to the front. I almost have all the dimensions just missing these last 2 Link to comment https://www.classiczcars.com/forums/topic/45350-1973-z-dmensions/ Share on other sites More sharing options...
February 18, 201312 yr comment_415347 So no one knows this? I have a completely disassembeld car hanging sideways in my back yard. Just to be sure, the front crossmember with the steering rack, the holes that bolt it to the frame of the car? TO: The rear lower control arm has two places it mounts to one towards the fron and one to the rear. I can measure that. Edited February 18, 201312 yr by bstrudg Link to comment https://www.classiczcars.com/forums/topic/45350-1973-z-dmensions/#findComment-415347 Share on other sites More sharing options...
February 18, 201312 yr comment_415349 So this is what I have. The front crossmember is not installed. I tied a string from the frame holes that hold the front crossmember to the frame, from one side to the other. I almost get a staight shot from the rear bolts. The distance from the rear bolt to the front holes 93 5/8in and from the same rear bolt to the front crossmember bolt is 97 1/8in. The rear control arm bolts that are closerto the front of the car are to close to the dip in the floor pans to get an acurate measurement. I hope this helps. Link to comment https://www.classiczcars.com/forums/topic/45350-1973-z-dmensions/#findComment-415349 Share on other sites More sharing options...
