Hey all, it's MY time to need some help!
Before I bailed out of Colorado to take care of sick family members, I used a NOID light to diagnose my Z's hard starting in very cold weather.
It simply came down to this. In sub-freezing weather I am sometimes NOT getting main injector pulses
Let it warm up a few degrees outside, and everything operates fine.
This was AFTER installing new injectors, a check valve, new cold start injector, diagnosing the thermotyme circuit, cleaning the AAR, and every OTHER possible source of hard starting problems. She starts instantly now -- except after a cold soak.
One time I finally caught her "in the act." Cranking, but no injection pulses. A minute later she was fine. Then I caught her again a few
days later.
I need some ideas as to what could be causing this.
Possibilities I've thought of include:
Worn or corroded contacts on main injection relay (voltage drop 'em?)
Temperature-sensitive Ignition module not sending signal to ECM so it's squirting (try hot air dryer?)
Voltage drop in main ignition switch signal controlling main injection relay?
What else should I look at as a possible cause of NO MAIN INJECTION during CRANK?
I think that the ECM gets its signal from the negative post of the coil, not the ignition module.
Are you sure that you're getting spark? No spark = no ECM signal = no injector grounding through ECM transistors.
Of course though, the same applies for spark - no reluctor pulse from distributor to ignition module = no spark = (see previous).
That's the chain of events, assuming that you have distributor-controlled timing and not a CAS (you have a ZX right?).
280ZX, and I confirmed spark during a crank no-start event. She immediately started upon application of starter fluid.
But I should probably re-confirm spark NEXT time I catch it "not injecting" since the problem is so intermittent.
Temperature-related is the clue....
Is there a possibility of heating suspected components with a heat gun one sub freezing morning one at a time to see if it will then start? Easy for me to say I don't even have a car with an ignition module!
Edited by Mikes Z car
