Posted January 10, 201312 yr comment_411511 Hey all, it's MY time to need some help!Before I bailed out of Colorado to take care of sick family members, I used a NOID light to diagnose my Z's hard starting in very cold weather.It simply came down to this. In sub-freezing weather I am sometimes NOT getting main injector pulsesLet it warm up a few degrees outside, and everything operates fine.This was AFTER installing new injectors, a check valve, new cold start injector, diagnosing the thermotyme circuit, cleaning the AAR, and every OTHER possible source of hard starting problems. She starts instantly now -- except after a cold soak. One time I finally caught her "in the act." Cranking, but no injection pulses. A minute later she was fine. Then I caught her again a fewdays later. I need some ideas as to what could be causing this.Possibilities I've thought of include: Worn or corroded contacts on main injection relay (voltage drop 'em?) Temperature-sensitive Ignition module not sending signal to ECM so it's squirting (try hot air dryer?) Voltage drop in main ignition switch signal controlling main injection relay? What else should I look at as a possible cause of NO MAIN INJECTION during CRANK? Link to comment https://www.classiczcars.com/forums/topic/45376-no-injection-pulse-cold-possibilities/ Share on other sites More sharing options...
January 10, 201312 yr comment_411533 I think that the ECM gets its signal from the negative post of the coil, not the ignition module. Are you sure that you're getting spark? No spark = no ECM signal = no injector grounding through ECM transistors. Of course though, the same applies for spark - no reluctor pulse from distributor to ignition module = no spark = (see previous). That's the chain of events, assuming that you have distributor-controlled timing and not a CAS (you have a ZX right?). Link to comment https://www.classiczcars.com/forums/topic/45376-no-injection-pulse-cold-possibilities/#findComment-411533 Share on other sites More sharing options...
January 10, 201312 yr Author comment_411535 280ZX, and I confirmed spark during a crank no-start event. She immediately started upon application of starter fluid. But I should probably re-confirm spark NEXT time I catch it "not injecting" since the problem is so intermittent.Temperature-related is the clue.... Link to comment https://www.classiczcars.com/forums/topic/45376-no-injection-pulse-cold-possibilities/#findComment-411535 Share on other sites More sharing options...
January 11, 201312 yr Author comment_411677 * fake post intended only to get thread listed on home page again and hopefully spur some comments* Link to comment https://www.classiczcars.com/forums/topic/45376-no-injection-pulse-cold-possibilities/#findComment-411677 Share on other sites More sharing options...
January 12, 201312 yr comment_411691 Is there a possibility of heating suspected components with a heat gun one sub freezing morning one at a time to see if it will then start? Easy for me to say I don't even have a car with an ignition module! Edited January 12, 201312 yr by Mikes Z car Link to comment https://www.classiczcars.com/forums/topic/45376-no-injection-pulse-cold-possibilities/#findComment-411691 Share on other sites More sharing options...
