Posted January 10, 201312 yr comment_411539 i have to remove my seats to repair the seat bottoms. the webbing has broke. what's the best way to remove them. all one piece out the door or out the hatch, or should i detatch the backs and remove? i fear ripping the interior with the bolts from the seat bottoms. tia Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/ Share on other sites More sharing options...
January 10, 201312 yr comment_411541 Once you remove the four bottom nuts from the seat bracket, the entire seat will slide easily out the door. It may be difficult to gain access to the inside seat back screws while the seats are still mounted. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411541 Share on other sites More sharing options...
January 10, 201312 yr comment_411543 13 mm box end wrench...13 mm pass-through socket. Those tend to be able to fit best on my 260Z. It's slow going, but as mentioned in post #2, just leave the seatbacks on and pull the seat out the door. Keep track of the spacers, too. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411543 Share on other sites More sharing options...
January 10, 201312 yr comment_411547 1. Loosen and remove 4 nuts holding the seat to the brackets.2. Lift seat and carefully manuever through fully open door.3. Put the spacers back on the seat mounting screws and thread the nuts back on so as to keep everything together. Edited January 10, 201312 yr by LeonV Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411547 Share on other sites More sharing options...
January 10, 201312 yr comment_411562 Remove the nuts from the rear mounts, first. Those are the most difficult to remove. If you removed the front mount nuts first, the seat will have a tendancy to teeter backwards making holding seat and removing the rear mount nuts a little more difficult. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411562 Share on other sites More sharing options...
January 10, 201312 yr Author comment_411585 my zed has a build date of 10/71 and is listed as a 72. i was informed that all 72 and newer have the spring bottom seats and that my seats must have been changed out with the earlier seats. can anyone confirm this info? Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411585 Share on other sites More sharing options...
January 10, 201312 yr comment_411588 my zed has a build date of 10/71 and is listed as a 72. i was informed that all 72 and newer have the spring bottom seats and that my seats must have been changed out with the earlier seats. can anyone confirm this info?I do believe that is incorrect. I will check on my 73 if/when I get home. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411588 Share on other sites More sharing options...
January 11, 201312 yr Author comment_411606 is there an exact build date or vin number when the change occured? Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411606 Share on other sites More sharing options...
January 11, 201312 yr comment_411613 is there an exact build date or vin number when the change occured?I was wrong. My 73 has springs, not webbing. According to the parts catalog, there were several seats, but one of the change dates appears to be 12/71, so during the 72 model year. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411613 Share on other sites More sharing options...
January 11, 201312 yr Author comment_411621 makes sense. my seats are correct then if the change was 12/71. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411621 Share on other sites More sharing options...
January 11, 201312 yr comment_411625 my zed has a build date of 10/71 and is listed as a 72. i was informed that all 72 and newer have the spring bottom seats and that my seats must have been changed out with the earlier seats. can anyone confirm this info?My 11/71 has webbing under the seats - I'm the original owner. I also did not get self retracting seat belts, nor a red seat belt warning light on the cover over the fuse box, nor waring buzzer. Also have vertical rear window defroster lines. The newer cars 12/71 or some time after had springs in the seats so the seat belt warning light and buzzer sensor could be installed. They also got self-retracting seat belts, horizontal rear window defroster lines.Some very early 72 Model Year Z's 09/72, came though without any "indentation" in the floor boards for the self-retracting seat belts as well. So there seems to have been a change over period of several months to add the things required by the 72 Safety Standards..FWIW,Carl B. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411625 Share on other sites More sharing options...
January 11, 201312 yr Author comment_411642 thankx carli called les to order seat foam and covers plus webbing and he told me that all 72 had springs and that my seats must not be original. my zed is setup like your car with pockets but no retractors. i'm going to check my seats out first to see if i only need repairs. they don't look to bad for wear but eventually i will have to replace foam and covers. Link to comment https://www.classiczcars.com/forums/topic/45378-seat-removal/#findComment-411642 Share on other sites More sharing options...
