New Problem! Car will only Idle now
Zachary Lawson
So my car was running pretty decent, just had a rough idle that I was working on. So I tried a few things like, screwing the air screw all the way in to find air leaks. Spraying the intake with brake cleaner (also in the air screw hole). After those troubleshooting processes,the car won't hardly even start now. It will only run at idle roughly. When you give it any sort of gas it dies. It seems to me like it overloading now. Sometimes it won't even start unless you unplug the fuel pump. Anyone have any ideas off the top of there head?
It's a 1978 280z, Stock everything.
Update:
So when I unhook the line from the air regulator It runs at about 6k or 7k rpm, but runs like it suppose too. I can give it gas and it will open up even more. Also If I take the air screw all the way out, it seems to improve it somewhat. It's acting like it's not getting any air. I can take the boot off the AFM and it runs at a very fast idle. I can put my hands around the AFM like how the boot should be. And the Engine runs like it's suppose too. If I unplug the cold start valve, should the motor change?
Edited by Zachary Lawson
You said it ran well with the hose between the AFM and the air filter removed. The only thing between the AFM and the "air" is the filter and the plastic tube to the air intake point. Did you check the rest of the intake system.
Maybe you meant the hose from the AFM to the throttle body? If so, it sounds like your AFM vane is stuck closed.
The things that you tried that raised the idle that made it run better all leaned out the mixture. Removing the AAR hose, taking off the AFM boot (AFM signal disappears), taking the air screw back (bypasses the AFM vane). Somehow you've made things too rich. Did you adjust the AFM spring? Accidentally knock the coolant temp sensor connector loose? Raise your fuel pressure somehow?
You might also have fouled some plugs. Brake cleaner is not designed to burn, like carb cleaner is. The old brake cleaner won't burn at all, I don't know about the new "green" stuff.
The funny thing about it is that it run fine until I just adjusted the air screw all the way in. Then after that it just ran awful. That's pretty much all I did. You think maybe I locked the flap closed? No I didn't adjust the AFM spring or mess with the fuel pressure. I'll update you with some test tomorrow. Thanks for all the help.
  • Who's Online   1 Member, 0 Anonymous, 652 Guests (See full list)
