Posted January 20, 201312 yr comment_412444 Im rebuilding all the brakes on my 280Z and now I am at the NP-valve (Proportioning valve) and the Brake indicator switch. The parts are ok, but I would like to replace all the seals. The NP-Valve is still availible at Nissan under P/N: 46400-P9200 but it cost $325,00. The Brake fail indicator switch is also only available as a complete unit. Internals are NLA. All I want are the internal seals and o-rings. Does anybody know where you can get the kits these days? Appreciate any help. Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/ Share on other sites More sharing options...
January 25, 201312 yr comment_413064 I would go to a parts store and match up the o-rings. The parts here locally have trays of o-rings for 'free-style' fitting. I am pretty certain it will be that way where you are too. It might be tricky to find the little one on the little plunger inside the housing. I think it is great you went the extra step to actually remove and repair the Proportioning Valve - most people ignore it. I am glad that you posted pics too, that will be good for the future. Let us know the outcome! Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413064 Share on other sites More sharing options...
January 25, 201312 yr comment_413066 I would be careful on material with the o-ring. Plain old plumbing o-rings might absorb brake fluid and swell (I tested an Ace Hardware o-ring to see if it could be used - it swelled). Viton would be fine if you can find them. I don't know what the typical material used is, and most manufacturers that I've seen don't list it. It's a problem. Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413066 Share on other sites More sharing options...
January 26, 201312 yr comment_413099 Most of the off the shelf O-rings you will find in the hardware store are Neoprene, or Buna-N (Nitrile). And I'm not so sure that I would jump on the Viton bandwagon so quickly... Viton (fluorocarbon) is not compatible with glycol based brake fluids. I have no idea what today's brake fluids are made from, but the incompatibility bore special mention in the application charts.Point I'm trying to make is do your research homework first. :bulb: Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413099 Share on other sites More sharing options...
January 26, 201312 yr Author comment_413123 Hi guys, Thanks for the input. Greatly appreciated.I agree, the O-Rings are easy to replace. When I find the sizes, I will post then.Most brake components are EPDM, but Im not sure if its sulpher cured or peroxide cured.Where I work we use a lot of O-Rings and gaskets and our experience with the peroxide variant is better in higher temperature conditions.This company is good for information about rubber compounds. A link to there site Datasheets | O-Ringen They recommend there 559311 compound which is peroxide cured EPDM.My biggest challenge is to find replacement cups. Its difficult to know where to start. I was thinking of trying a brake specialist and looking at what he has that might fit.My goal is to retain the original proportioning valve and not replace then with some aftermarket unit. Trying to keep a bit of original look in the car.Ill keep you posted.Chas Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413123 Share on other sites More sharing options...
January 26, 201312 yr Author comment_413124 Hi Zcurves,Your idea is just what I had in plan. Take to parts to a hydraulic shop and find which o-rings fit best. Then order then in EPDM.Chas Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413124 Share on other sites More sharing options...
January 26, 201312 yr Author comment_413148 Found the size of the two o-rings today. The two behing the nuts.Size 16.39x2.21mm (IDxCross section) according to standard AS568-908. The cups are going to be harder to solve if at all. Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413148 Share on other sites More sharing options...
January 26, 201312 yr comment_413150 Captain Obvious said: not so sure that I would jump on the Viton bandwagon so quickly... Viton (fluorocarbon) is not compatible with glycol based brake fluids. I have no idea what today's brake fluids are made from, but the incompatibility bore special mention in the application charts.You got me. I made an assumption (that all fluoropolymers would be fine with brake fluid), and a bad suggestion. I should know better. Sounds like Eurodat has the best resource for figuring out what will work. Interesting thread. Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413150 Share on other sites More sharing options...
January 27, 201312 yr comment_413192 Yeah, once you get used to Viton's oil and fuel resistance, it's easy to get lulled into thinking it's the cure-all for all automotive applications. I've thankfully not designed any obscure O-ring assemblies in my travels and I've not messed with brake fluids to date. That will probably change if I get energetic and split my front calipers though. And at that time I will require a reading from the book of Parker. BTW - A little off topic, but did you know that burning Viton is a really, really bad idea? Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-413192 Share on other sites More sharing options...
March 21, 201312 yr Author comment_418554 Hi all, Finished rebuilding my brake switch. Luckely the bore was not too bad and cleaned up nicely with 500 and then 1000grit wet&dry. Made a hone out of a BIC pen by cutting a slot in it and using a 10mm strips of wet&dry. 280Z Brake Switch: (The sizes are ID x Cross section. The material is EPDM) The shuttle has two O-rings. 1x 6.07x1.78mm. AS010 1x 4.90x1.90mm. R4 The brake switch has an O-ring seal 1x 10.82x1.78mm. AS013 Proportioning Valve: Not much luck on finding any replacement parts for it. I did find some cups that fitted, but the brake workshop didnt know which old car they came from. He just had a box of loose ends he kept out the back. He said, If I could find anything I could keep it. Chas Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-418554 Share on other sites More sharing options...
July 8, 201410 yr comment_451232 i see that zcs in arizona has Brake Fluid Switch 12302302 @ 109.99 and np valve listed 12202401 price tbdused - but better than nothing... Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-451232 Share on other sites More sharing options...
July 8, 201410 yr Author comment_451233 The last I have heard is that the np valve is now nla. I managed to clean mine up and reuse it. The switch just needed a set of o-rings. Its been 1 1/2 years and they are still working fine.Chas Link to comment https://www.classiczcars.com/forums/topic/45461-parts-for-oem-np-valve-and-brake-indicator-switch-unit/#findComment-451233 Share on other sites More sharing options...
