Posted January 25, 201312 yr comment_413060 Trying to replace the seals on a 1979 280zx transmission.Can't figure out how to take off the striking guide on the rear extension - looks like I need to maybe remove the striking lever first and maybe the whole striking rod will slide out...? But I can't get the bolt off of the lever; does the guide disconnect another way?Thanks. Link to comment https://www.classiczcars.com/forums/topic/45509-striking-guide-striking-lever/ Share on other sites More sharing options...
January 25, 201312 yr comment_413068 You have to take the striking lever off first. Then the striking rod and gide slide out the back as a unit. Link to comment https://www.classiczcars.com/forums/topic/45509-striking-guide-striking-lever/#findComment-413068 Share on other sites More sharing options...
January 25, 201312 yr Author comment_413079 You have to take the striking lever off first. Then the striking rod and gide slide out the back as a unit.Thanks for your response.Any tricks to get the bolt out of the striking lever? I took off the nut but the bolt won't budge; no head to grab on to; I tried heating it up and whacking the bottom on the bolt on the threads but nothing is happening... Link to comment https://www.classiczcars.com/forums/topic/45509-striking-guide-striking-lever/#findComment-413079 Share on other sites More sharing options...
January 26, 201312 yr comment_413111 Yes, the lock pin is difficult to get out. We made a lever with a wedge shaped end to push it out using the case as the fulcrum. Also, if I remember correctly, we made a support plate for the end of the striker rod that bolted to the edge of the tail housing so the rod will not bend. Nothing to fancy. Made them from an aluminum bar about 1" x 1/2" x 24", something like that. Drill, cut and shape to fit with hand tools. No high presicion required. Edited January 26, 201312 yr by beermanpete Link to comment https://www.classiczcars.com/forums/topic/45509-striking-guide-striking-lever/#findComment-413111 Share on other sites More sharing options...
January 26, 201312 yr Author comment_413138 Yes, the lock pin is difficult to get out. We made a lever with a wedge shaped end to push it out using the case as the fulcrum. Also, if I remember correctly, we made a support plate for the end of the striker rod that bolted to the edge of the tail housing so the rod will not bend. Nothing to fancy. Made them from an aluminum bar about 1" x 1/2" x 24", something like that. Drill, cut and shape to fit with hand tools. No high presicion required.got tired of trying to coax that bolt out so i just cut the rod. Link to comment https://www.classiczcars.com/forums/topic/45509-striking-guide-striking-lever/#findComment-413138 Share on other sites More sharing options...
January 26, 201312 yr Author comment_413170 got tired of trying to coax that bolt out so i just cut the rod.Turns out getting a replacement striking rod for a 280zx isn't that easy; does any one have one they can sell me? I think the ones from 240sx, 200sx also fit. Link to comment https://www.classiczcars.com/forums/topic/45509-striking-guide-striking-lever/#findComment-413170 Share on other sites More sharing options...
