January 29, 201312 yr comment_413357 Good luck on that. I haven't seen those listed anywhere for a long time...of course, it's been a while since I've searched. Link to comment https://www.classiczcars.com/forums/topic/45521-240z-rear-bumper-guard-rubber-strip/?&page=2#findComment-413357 Share on other sites More sharing options...
January 29, 201312 yr comment_413359 I would recommend selling your re-chromed '73 guards, buy some '70-'72 guards and then use your 4-bolt rubber strips. The larger '73 guards were set closer to far ends of the bumper than the '70-'72 guards were and in my opinion would not look right on the older bumper. Besides, as you have found out, it's going to be tough trying to find some '73 rubber guards and your re-chromed guards should sell quickly. Link to comment https://www.classiczcars.com/forums/topic/45521-240z-rear-bumper-guard-rubber-strip/?&page=2#findComment-413359 Share on other sites More sharing options...
January 29, 201312 yr comment_413365 OK,..I have found the problem. My 1972 has 1973 guards on it. Apparently, the 70-72 had he 4 hole configuration anf the 73 had the 3 hole. Not sure how 73 guards ended up on my 72, (with build date of 02/72).Now I just need to find some 73 rubber strips.I think you have it backwards. The 70-72 had three holes in the guards and studs in the rubber strips. The 1973 had four. Here is a set of the rubber strips with the three studs you said you were looking for: Datsun 240Z Front Bumper Overrider Guard Rubber Strip Set 1970 72 New | eBay-Mike Link to comment https://www.classiczcars.com/forums/topic/45521-240z-rear-bumper-guard-rubber-strip/?&page=2#findComment-413365 Share on other sites More sharing options...
January 29, 201312 yr Author comment_413369 I think you have it backwards. The 70-72 had three holes in the guards and studs in the rubber strips. The 1973 had four. Here is a set of the rubber strips with the three studs you said you were looking for: Datsun 240Z Front Bumper Overrider Guard Rubber Strip Set 1970 72 New | eBay-MikeThis auction is for a set of FRONT rubbers. I am looking for the REAR rubber strips. Thanks though. Link to comment https://www.classiczcars.com/forums/topic/45521-240z-rear-bumper-guard-rubber-strip/?&page=2#findComment-413369 Share on other sites More sharing options...
January 29, 201312 yr comment_413370 I see. I didn't catch that. Good luck with your search then. Link to comment https://www.classiczcars.com/forums/topic/45521-240z-rear-bumper-guard-rubber-strip/?&page=2#findComment-413370 Share on other sites More sharing options...
